Old 12-08-2003, 12:34 PM   #1
DeanTX
Member#: 48635
Default How to unplug wiring connector to front door panels ?
Alright, sad question, but I have to ask - didn't want to break anything last night...
I *attempted* to remove the door panel, following the FAQs here... what is the best way to unplug that wire connector that goes to the bottom of the door controls ? There's two things on the end and I squeeze them..and well, things don't loosen.
Do I simply grab the mo-fo and pull as hard as possible, or do I need to squeeze and pry with a flattip screwdriver at the same time ?
Figured I'd ask before attempting brute force.... Thanks for your help with my sad question!
DeanTX is offline   Reply With Quote
Old 12-08-2003, 01:35 PM   #2
tcs007
Member#: 4103
2016 Mazda6
Red
Those are kind of a pain. Just slowly work them with a combo of brute force and a small flat tip screwdriver.
tcs007 is online now   Reply With Quote
Old 12-08-2003, 02:57 PM   #3
Jakezor
Member#: 9624
2002 ImprezaWRXsedan
Platinum Silver Metallic
There should be a little section to press in with your fingertip or a screwdriver.
Jakezor is offline   Reply With Quote
Old 12-08-2003, 05:07 PM   #4
Cardiff Giant
Member#: 40325
2013 Nissan Rogue
Don't try to remove the harness itself, just release the trim from around the switch. It took me forever to realize that. Now I can have the panel off in like a minute.
Cardiff Giant is offline   Reply With Quote
Old 12-08-2003, 05:18 PM   #5
DeanTX
Member#: 48635
Thx, Cardiff Giant..I thought about that (just removing the trim from the controls itself) but visions of little springs and little switches all popping out kinda scared me...so I thought I would just post first... but now you've given me reassurance..I'll just do that!
Old 12-09-2003, 05:20 PM   #6
Cardiff Giant
Member#: 40325
2013 Nissan Rogue
Dean, no problem. I actually installed two different sets of front speakers(installed some cheap Pioneers and then two months later decided to replace them with some nice Polks) and one rear set without disconnecting the window controls(I just moved the panel and held it while I was installing the speakers). It was a TOTAL pain but it was doable. Then when I decided to fix this resonation and install dynamat, I finally realized that If I just took a flat head screw driver and GENTLY released the clips that hold the window trim in place that I could take the plastic off and feed the controls through the opening in the door handle. I felt like a complete idiot for not having thought to try that before
Hope it all goes well for you!
Old 12-09-2003, 07:31 PM   #7
Rally1
Member#: 20633
Did you guys snake new speaker wire out there somehow? Or just tap the existing wire. I need to get from my amp to the speaker in the door, but i can't see an easy way to get that wire up in there.
Rally1 is offline   Reply With Quote
Old 12-09-2003, 10:28 PM   #8
02SilvaWagon
Member#: 33933
2011 WRX Limited
I snaked two runs of 16 gauge speaker wire, along with 4 other wires for window modules thru the drivers door boot. 2 runs of speaker wire for the front passenger door, and 1 run each into the back doors. Not that hard if you have a metal snake.
02SilvaWagon is offline   Reply With Quote
Old 12-10-2003, 07:16 AM   #9
Scooby Freak
Member#: 40751
'94 SER
I ran two sets to each front door. It was tough, a couple hours busting my knuckles. I pulled the grommets away from the door and car and removed the tape, then used a coat hanger to fish the wires up through. It was tough to get the grommets back in, because there's not much room for leverage.
02SilvaWagon - Can you snake the wires w/o separating the boot from the door? And for the rear doors, Did you have to remove part of the side air bag system to access the wires in pillar?
As for the plug in the door controls, I pryed with a screwdriver while pushing the tab in (do not do this), nearly broke the tab off, but the connector still holds tight.
Scooby Freak is offline   Reply With Quote
WTT NJ: 06 WRX TR Front Door Panels for 05+STi Panels NJPunkerWRX Tri-State Area Private Classifieds 2 06-24-2008 06:36 PM
How to remove 05 STI front door panels? Inprogress Car Audio, Video & Security 5 06-16-2006 01:54 AM
Wtb: 02 Wrx Front Door Panels firebottle Private 'Wanted' Classifieds 1 12-09-2003 10:48 AM
front door panels shingles STi Forum Archive 1 05-23-2003 10:57 PM
taking off front door panels... please help:) nav Car Audio, Video & Security 4 03-22-2001 01:02 AM
