Old 12-08-2003, 11:26 PM   #1
98LegacyGT
Member#: 37354
1998 Legacy GT
Default HVAC Problem
Hey guys,
I just changed the HVAC bulbs in my 98 Legacy GT . . . it's nice to be able to see the HVAC controls at night!
Unfortunately, after I put everything back together, I am no longer getting any hot air from the vents when I set the temp control in the "red zone" of the gauge (ie. hot temp). Can anyone help me out and let me know what may be causing this?? Thanks.
98LegacyGT is offline   Reply With Quote
Old 12-09-2003, 01:37 PM   #2
MikeKlacy
Member#: 47775
2005 LGT Wagon
Regal Blue Pearl
whats the part number for the HVAC bulb? I too need to fix em'.
MikeKlacy is offline   Reply With Quote
Old 12-10-2003, 02:38 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I would guess a control rod is no longer connected, or a vaccuum line is crimped.
Probably the best thing is to pull it apart again.
Old 12-10-2003, 04:16 PM   #4
richeich
Member#: 1353
2001 Impreza 2.5RS
Did you get the steel cable re-attached. It's connected to the temp control lever, and goes down to the right of the console up under the dash a bit. It controls the temperature, and if it's loose at one end or the other, it won't control squat! I've done a couple of different HVAC's now, and have discovered that it's easier to disconnect that cable down at the bottom end, under the dash. It's just easier to reach.
Hey Mike, for instructions and maybe even pictures, check www.scoobymods.com and see if you can find it there. It shouldn't be too hard. I'll check around over there and give you a direct link.
Rich
richeich is offline   Reply With Quote
Old 12-10-2003, 04:19 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Here it is... link
HVAC problem sum0325 Electrical & Lighting 8 02-15-2009 06:33 PM
HVAC problems Matt Mid Atlantic Impreza Club -- MAIC 0 02-23-2008 09:44 PM
HVAC problems qoncept Service & Maintenance 2 12-19-2005 03:58 PM
HVAC problems! SubaruImpreza_power Service & Maintenance 6 01-29-2004 12:28 AM
HVAC Problem 98LegacyGT Electrical & Lighting 2 12-10-2003 11:17 AM
