Old 12-09-2003, 12:10 AM   #1
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Default Weight of stock WRX seats
I'm debating whether to replace my stock WRX seats with Sparco Evo2's (which fit me like a glove) for better fit & lateral support. The final deciding factor will be weight savings, or lack thereof.
I've searched high & low, and can't find the weight of the stock WRX seats listed anywhere! Can anyone save me the effort of pulling out my seats & weighing them?
Thx!
-Steve
MNbiker is offline   Reply With Quote
Old 12-09-2003, 10:08 AM   #2
ITWRX4ME
Member#: 24472
2001 Miata
I've taken my driver's seat out, but not weighed it. I'd say it's in the vicinity of 35-40 lbs. The passenger seat should be a few pounds lighter because it doesn't have the height adjustment.
There was a great thread here months ago that had the weights of nearly everything removeable. Might want to search the archives.
BTW, if you can't find that, the seats are easy to remove. 5 minutes tops.
ITWRX4ME is offline   Reply With Quote
Old 12-09-2003, 10:15 AM   #3
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Yeah,
I saw that great thread, but it didn't include front seat weight!
Oakos has an excellent list of parts weights....but again, no front seat weights!
http://www.oakos.com/wrx/weights.htm
Anyone gonna save me the effort of pulling out the seats?
-Steve
Old 12-09-2003, 11:34 AM   #4
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
I bet you $1000 that the sparcos will be lighter then the stock seats. Our brackets are heavy too.
Just buy the drivers evo 2 and don't worry about the passenger side
-Tom
trhoppe is offline   Reply With Quote
Old 12-09-2003, 01:06 PM   #5
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Smartass!
Here I am, trying to find excuses NOT to spend money for a change (well, not really, but that's what I'm tellin' the wife!).....
Old 12-09-2003, 02:04 PM   #6
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
ding ding
-Tom
Old 12-09-2003, 03:58 PM   #7
MNbiker
Member#: 18148
'08 WRX
Dark Gray
ding ding
-Tom
I suppose I could install some of those nice, comfy $100 Kirkey's instead.
(Rode 5 hours to Milwaukee in a buddy's RX-7 with cheap Kirkey's installed in it......NEVER, EVER doing THAT again! We had to stop every 60 miles or so to rest our aching kidneys, backs, necks, etc.)
Old 12-10-2003, 12:51 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I think they are closer to 60lbs w/ brackets, especially cause of the airbags. They are not light, folks say it takes two people to get them out
Old 12-10-2003, 07:08 AM   #9
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
I know I can barely carry a stock seat around by myself... gotta be at least 40 pounds.
ellisnc is offline   Reply With Quote
Old 12-10-2003, 09:50 AM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I don't think they are anywhere near 60lbs. _Maybe_ 40 lbs. The airbags don't really weigh anything at all, the weight is in the base and mounting. (I've taken the backs off my WRX seats numerous times, where the airbag is located). Honestly I couldn't tell a huge difference between the weight of them and my STI V7 seats that I have now. 1 person can certainly carry one and remove it from the car. You want heavy you should lift my friends S4 seats, I think they are 120lbs apiece...
Old 12-10-2003, 12:51 PM   #11
ITWRX4ME
Member#: 24472
2001 Miata
Like I said, I've removed mine by myself. I was able to lift it, no problem.
Old 12-10-2003, 03:48 PM   #12
Uber Wagon
Member#: 39600
2008 STi
Dark Grey Metallic
I had asked this question earlier and got the following response:
http://forums.nasioc.com/forums/show...hreadid=448493
This seems about right although I haven't verified myself.
-Nick
Uber Wagon is offline   Reply With Quote
Old 12-11-2003, 02:22 PM   #13
MNbiker
Member#: 18148
'08 WRX
Dark Gray
-Nick
So the total weight savings for both seats should be approx. 50 lbs (or maybe a bit more, depending on bracket/slider weights).
I'll probably end up doing this by Spring. If so, I'll post as-installed weights for both the stock & Sparco Evo2 seats for reference.
-Steve
Old 12-13-2003, 10:01 PM   #14
hotrod
Member#: 14141
2002 Impreza WRX
Default front seats
The front seats weigh very close to 50 lbs. I attempted to weigh mine using 2 different scales. Unfortunately they were over max weight on one scale and low on the weight range of the other scale so accuracy of both were less than Ideal. I came to the conclusion that the seats (passenger side front 2002 WRX) is approx 52 lbs +/- 2 lbs.
Larry
hotrod is offline   Reply With Quote
Old 12-14-2003, 12:07 AM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
55lbs. Just weighed mine.
jblaine is offline   Reply With Quote
Old 12-14-2003, 03:23 AM   #16
MK19
Member#: 21977
Bear s like food
2004 front seat weights 46 pounds with rails- the 02-03's weight a bit more... I know- I have shipped enough of them around
MK19 is offline   Reply With Quote
Old 12-14-2003, 09:40 AM   #17
WRX-ECE
Member#: 12091
Old 240Z Broken
Rally car, 350z, 98 RS
-Steve
For STX? I thought we were limited to non-shell fixed back seats or did I miss something...
Jeremy
WRX-ECE is offline   Reply With Quote
Old 12-14-2003, 11:13 AM   #18
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
The stock seats weighed about 45 lbs each when I pulled mine out.
My total weight savings after installing my Nex race seats with sliders was just over 60 lbs total.
Templar is offline   Reply With Quote
Old 12-14-2003, 11:16 AM   #19
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Honest... they're exactly 55lbs each for 2002/2003. My scale is accurate and I weighed it carefully.
Old 01-31-2004, 12:57 AM   #20
AUTOwrXER
Member#: 5817
2005 STi
That is with the mounting hardware, correct?
AUTOwrXER is offline   Reply With Quote
Old 02-01-2004, 12:42 AM   #21
aspera
Member#: 7879
Are the newer seats lighter? That might be a good upgrade for some 02/03 owners.
I really want to get some Bride subframes. They look much lighter than anything else I've seen. I just can't find any sellers.
aspera is offline   Reply With Quote
Old 02-12-2004, 10:08 AM   #22
BIGSKYWRX
Member#: 7958
09 GH B+
Is that w/ brackets? Would the driver's side be a bit more w/ the adj height? Any idea on weight w/o bracket?
I'm doing some comparos w/ a few different seats, want to be able to justify upgrading.
aspera- pics of the Bride subframes? These would work w/ any after market seat? or just Bride seats?
TIA
Big Sky
Old 02-12-2004, 05:22 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Yes, that was with everything bolted to the bottom. Remove from car via 4 main mounting bolts, drop on scale = 55lbs.
No idea on weights other than that, sorry.
Old 02-15-2004, 01:31 AM   #24
aspera
Member#: 7879
http://www.tees-usa.com/seatrail.html
I don't know, but I'm hopeful that the Bride FO type or FG type will work with Sparco side-mount seats. If not, they look like they could be MADE to work. The reason that I like the Bride seat rails is that they use the sliders as part of the subframe structure. That should make them lighter and lower. The FG type is even more extreme. It gets rid of lots of steel.
Old 02-15-2004, 10:13 PM   #25
FatChanceTi
Member#: 274
I have a pair of the BRIDES, and the uprights were far too narrow (although they are not pictured on the link above). Unlike the ones at the link, mine arrived as one piece units, no bolt-on uprights. BUT - they were WAY too narrow for a typical Sparco, Momo or Recaro seat. I had to cut off the stock uprights and replace them with a set of traditional steel side-mount seat brackets. BRIDE seats must be VERY narrow.
My BRIDE mounts fit the car (GC8) perfect though, and have none of the slop that you sometimes get with the common "bolt together" solutions that are typical here (wedge).
If you PM me your email address, I can send you before and after pictures of my BRIDE seat mounts.
FatChanceTi is offline   Reply With Quote
dose anyone knows the weight of stock wrx crossmember?! qtr_wrx Newbies & FAQs 2 05-14-2007 05:09 PM
Weight of stock WRX wheels jetsiphon Tire & Wheel 6 05-01-2003 01:32 PM
Weight Of stock WRX 16 in. wheels randykyra Brakes, Steering & Suspension 2 09-11-2002 09:36 AM
Weight of stock WRX rims? Midnightman Brakes, Steering & Suspension 5 12-26-2001 11:34 AM
Weight of stock WRX wheels, P7's, and how much difference does it make? WR-REX Brakes, Steering & Suspension 4 09-21-2001 12:05 PM
