Old 12-09-2003, 01:21 AM   #1
chri3
Member#: 16245
Default OBS to WRX front brake conversion....moving the front discs to rear
Has anyone done this? I can get a set of WRX front brakes, but i don't want to have too much front bias, and i don't like the concept of drums. what would i have to do to swap out the fronts, and move the front discs to the rear. Has anyone done this, or does anyone know what it would entail?
thanks
chri3 is offline   Reply With Quote
Old 12-09-2003, 02:47 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Doesnt work like that... You have to swap the whole hub to get discs on the rear.
Old 12-09-2003, 11:19 AM   #3
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Yup, what Kosta said. Also, when you're hunting for your rear discs/hubs, make sure you get them from an ABS equipped car if your OBS has ABS. Good luck.
- Trent
peepshow is offline   Reply With Quote
Old 12-09-2003, 12:46 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The other thing everyone seems to be forgetting is the parking brake. The rear hub has an integral drum for the parking brake. If you somehow put your front rotors on the rear of the car (good luck with that ) you wouldn't have a parking brake when you got done .
Brian
Old 12-09-2003, 03:30 PM   #5
chri3
Member#: 16245
So basically it's a big pain in the arse? my OBS is an MY02. If i fet like every brake component from a WRX would it be doable? Are the master/slave cylinders the same?
Old 12-19-2003, 01:21 PM   #6
cybin
Member#: 48667
You should go to the website below. It has all the info about swapping drum for discs on the rear for a OBS. Now I'm just wondering is I can get WRX brakes to fit the front and rear of my OBS.
http://wac.addr.com/auto/obs/obs.html
cybin is offline   Reply With Quote
Old 12-19-2003, 02:32 PM   #7
codger
Member#: 13486
06 Legacy GT wagon
I've done it. the front and rear brakes from an '02 WRX bolted right on to my '02 OBS. No bias problems either. If you search on my username in this forum and keyword "drum" you should find a bunch of info on part numbers for master/slave cylinders etc. IIRC, it is the same part number, same split point and reducing ratio on the proportioning valve etc.
With SS lines the braking is noticeably more controllable. Also I have STI suspension now, so less brake dive, hence more use of the rears. Don't bother with the swap unless you have plans for:
upgraded suspension like that, plus upgraded pads, plus some engine mods,
or long mountain descents,
or pulling a heavy trailer,
codger is offline   Reply With Quote
Impreza L to 03 WRX front brake conversion timpreza5 Brakes, Steering & Suspension 15 05-29-2008 07:40 PM
2.5rs to wrx front brake conversion, what is up?? qualityracer Brakes, Steering & Suspension 3 05-22-2008 02:15 PM
quick question on rs to wrx front brake conversion doubledribble Brakes, Steering & Suspension 2 12-21-2006 04:13 PM
RS--> WRX front brake conversion- small questions Concillian Brakes, Steering & Suspension 8 08-27-2003 04:48 PM
Can you move the front door speakers to the back door in the WRX? Cjchaps Car Audio, Video & Security 1 08-29-2001 10:44 PM
