Old 10-02-2000, 08:40 PM   #1
veowsaku
Member#: 1372
2005 Legacy Wag LTD
Post Tire presure?
What are your tire pressures?
I have 34F and 32R.
Khem
96' 2.2 Lxi wagon
veowsaku is offline
Old 10-02-2000, 08:45 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Depends on what tires you have & what you're doing with them (cruising, autoxing, etc).
RidinLow is offline
Old 10-02-2000, 09:46 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Post
I'm running stock tires(yuch, I know). I'm running them a few couple lbs. over recommended pressure. 34's up front and 31's in the rear and I check it once every couple of weeks.
HomerJay is offline
Old 10-02-2000, 09:54 PM   #4
Evil-Mastermind
Member#: 2068
08 VW Rabbit
United Gray
Post
okay, what about the Kumho's in the stock size? What are you running street/track?
Evil-Mastermind is offline
Old 10-03-2000, 12:11 AM   #5
wistful
Member#: 745
2004 STi
Java Black Pearl
Post
yikes. I guess i'm running it high. Cruising in highway, I leave 'em at 40/35. Isn't this better for gas mileage? Auto-xing... 60/55 =) max psi. 44 my butt.
don
wistful is offline
Old 10-03-2000, 03:42 AM   #6
chillN 2.5RS
Member#: 1555
2K RS
BRP
Post
i am running stock tires at max psi 44 thinking bout going higher to like 46 maybe even 48
my sides wore out like a champ lost the endline real fast. yep i don't like to slow down for turns. but i still got a lot of meat on the middle
chillN 2.5RS is offline
Old 10-03-2000, 05:22 AM   #7
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Post
I'm running my stock size Kumho's at 37/28 on the street. Haven't had them out to an auto-x yet but I will most likely start out at 44/40 and see how it goes.
Opie is offline
Old 10-03-2000, 06:37 AM   #8
Gambit
Member#: 102
Post
If you're refering to RE92s...they are very lumpy! You need to pump them higher to prevent that bottom bulge.
disclaimer : please do this at your own risk.... after all it's a Brigdestone product.
Gambit is offline
Old 10-03-2000, 06:47 AM   #9
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Talking
Hey, the Bridgestone/Firestone tires only pop when underinflated!
Anyway, I run Pirelli P8000 Vizzolas at 46/42 all the time. AutoX and street. I like the feel and response. The chalk lines on the tires are always right at the sidewall mark, so I'm right on with the optimum all-around pressure. Yay.
Here is the same tire at street pressures (32/29)...note how bad the chalk is marked onto the sidewall:
Trunkmonkey is here! There is no cone...
Sean Sosik-Hamor < [email protected] >
Epinions Automotive Reviews by `Sean
47STS MY98 Subaru Impreza Outback Sport
[This message has been edited by Sean (edited October 03, 2000).]
Sean is offline
Old 10-03-2000, 07:09 AM   #10
uktena
Member#: 1267
Exclamation
P7000 SS 205/50/16 40F 38R
uktena is offline
Old 10-03-2000, 09:17 AM   #11
DuneHopper
Member#: 1249
2000 OBS
Post
P7000 SS's. 205-55/16, 38f/36r, for street use.
DuneHopper is offline
Old 10-03-2000, 09:44 AM   #12
cakagan
Member#: 251
1998 Impreza 2.5 RS
Post
I've got Kumho Ecsta 711s, stock size, and I run 38f/35r. I just drove up Pikes Peak Saturday afternoon and I was able to get throttle-induced oversteer around the gravel switchbacks. It's pretty good on the paved streets, too. I have the stock rear bar, btw.
Opie-
How's the wear on your rear tires at 28? What is the car like at that tire pressure? Hmmm...
-Chris
[This message has been edited by cakagan (edited October 03, 2000).]
cakagan is offline
HTML code is On
tire presure ??? imprez_kyoso Texas Impreza Club Forum -- TXIC 4 06-08-2002 12:50 PM
Auto-X tire presures WRX 2002 Brakes, Steering & Suspension 16 05-30-2002 01:40 PM
rear tire presure and O/U steer savka Brakes, Steering & Suspension 4 02-19-2002 12:38 AM
WRX stock tire presure fourortwowheels Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-01-2001 01:36 PM
what kinda tire presures do they run in the wrc? Ghostrider Motorsports 0 07-07-2001 05:26 AM
