Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-27-2000, 11:30 AM   #1
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Angry Dam windows!
I am getting tired of my windows fogging up and leaving a film on the windows. Does this happen to anyone else? If so any way to provent it.
Thanks,
Mad Max - MY00
MadMax is offline
Old 06-27-2000, 11:52 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Same here. And the dash getting dusty 2 minutes after you clean it. *shrug* Maybe they invented magnetic plastics?
8Complex is offline
Old 06-27-2000, 11:54 AM   #3
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Flip the lever on your AC control so that it is coming in from outside instead of recycling inside.
blaster88 is offline
Old 06-27-2000, 12:00 PM   #4
subapooh
Member#: 892
Post
I got a small bottle of "fog off", this spray on liquid which me and the fellas use to treat our masks when we go paintballing, and it's working damn well on the scoob!!
[This message has been edited by subapooh (edited June 27, 2000).]
subapooh is offline
Old 06-27-2000, 12:28 PM   #5
uktena
Member#: 1267
Exclamation
When I worked for BWM; they touted the fact that they a used a special process for manufacturing the plastic pieces for their interiors that wouldn't fog the inside glass. So, I've always assumed that was what was happening with my car. But; can't say for certain.
uktena is offline
Old 06-27-2000, 12:33 PM   #6
SubieRacer
Member#: 775
Thumbs up
Listen to Blaster!
Honda even addresses this problem in their owners manual info and they tell you just what Blaster said.
No I don't and never have owned a Honda...I just know.
curtis
that damn gen x kid
SubieRacer is offline
Old 06-27-2000, 12:49 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Mine is pulling air from outside and still doing it. Though mainly it only does it when I don't have any air going (and sometimes with the windows open, just later at night during the start of dew forming around).
8Complex is offline
Old 06-27-2000, 03:08 PM   #8
Doc
Member#: 1117
Cool
If you are having problems with your windows why not try Unix
Doc is offline
Old 06-27-2000, 05:22 PM   #9
uktena
Member#: 1267
Exclamation
I always leave the fresh air control open the average humitity here is around 12 - 20%; I know the crap on my windows is chemical fog. Which will, in turn, make humitity fogging worse; if you live in a humid area.
uktena is offline
Old 06-28-2000, 01:17 AM   #10
bryanw
Member#: 807
2002 WRX Wagon
Post
Mine fogs over all the time to and I ALWAYS leave it on the outside air position. The best way to handle it is to periodically turn the defrost (heat of course) on full blast for 20 seconds. That'll clear it up for quite a while. The worst I've seen is it refogging every 10 minutes. Cracking the windows doesn't help. A/C doesn't help either. An open sunroof helps a little, but not very much.
bryanw is offline
Old 06-28-2000, 01:23 AM   #11
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Post
The reason is that the cabin inside the Prezy is very tightly sealed. You'd have to crack the moon roof to let the air flow out quicker from the vents. Try driving with your vents on Fresh and with the fan off and all the windows and moon roof closed. Feel the air flowing from the vent. not much air flowing in, huh?
Now open the moon roof - feel a surge of air coming from the vents now. Big difference.
The Prezy is tightly sealed hence the breathing will leave a film on teh windows.
[This message has been edited by Snoopy (edited June 27, 2000).]
Snoopy is offline
Old 06-28-2000, 01:29 AM   #12
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Lightbulb
i think i gonna remove all the windows. whadda think?
MadMax is offline
Old 06-28-2000, 01:35 AM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Actually you should use the A/C versus the heat to get fog off your windows. I believe the concept behind A/C is to remove the humidity from the air and it'll clear up your windows before you can even get the heat to be warm. Try it, you'd be amazed.
8Complex is offline
HTML code is On
Window will roll down but not up!? GoneSingle Electrical & Lighting 2 08-04-2010 01:50 PM
2002 Front air dam lip. Where can i buy this? ThinkTank Interior & Exterior Modification 8 06-09-2001 01:27 AM
front air dam for a '94? RaceCarRiot Interior & Exterior Modification 8 06-01-2001 01:54 AM
Geezuz dam Efoo Mumbles New England Impreza Club Forum -- NESIC 3 09-11-2000 07:15 PM
Scooby Sighting - Shamokin Dam, PA Narso Mid Atlantic Impreza Club -- MAIC 0 06-17-2000 06:28 PM
