Old 12-09-2003, 07:52 PM   #1
a dub d
Banned
Member#: 49909
Question Options for swaps into MY93 Impreza
First post, but have been searching this forum, read the sticky, and made a lot of phone calls...
I was basically given a 1993 Midnight blue 2dr 5spd Impreza with 125K miles.
I have a budget of about $7k to work with on this car...but the priority is going to be performing a motor swap and then paying small attention to the appearance of the car(2.5RS stuff) I currently work at a motorsports shop that races/modifies Porsches and Audis, so I can do a lot of the work myself.
I've been looking at front clips on eBay and other sites mentioned on this board. I know that wiring, while complicated, is not tough. If I understand correctly, the motor drops in, using a different cross-member....etc...
My question is:
What do I need to look for in regards to a front clip?
Do I need to find one of the same year?
Who is a reputable importer of such clips?
What is the aftermarket for these J spec motors?
What, other than the complete clip, will I need to locate?
If I dont do this swap at my shop, who in Texas has done this type of swap?
I know these questions have been asked prob. a million times already, but Im just looking for a professional oppinion.
I really appreciate the help!
a dub d is offline   Reply With Quote
Old 12-10-2003, 12:13 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Is it AWD or 2WD? What do you plan on doing with it?
Old 12-10-2003, 01:55 AM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
i dont think there were 2drs in 93, but i could be wrong.
you dont have to have the same year but it helps. obd1 vs 2. you will need a motor/turbo/cooler, wire harness/ecu, turbo subaru front crossmember, clutch, and tranny would be a good idea too, maybe brakes.
as for jdm stuff i hope someone else will chme in
RS_to_WRX_swap is offline   Reply With Quote
Old 12-10-2003, 11:09 AM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
If I were you and had that car and that money, I think I would stick to the US market. I would probably just get an EJ20 with the tranny and ECU and all the other stuff and swap that in. It would be the easier and you would have so much money left over to play with. Just an option. Good luck.
Brent
scoobyimprza is offline   Reply With Quote
Old 12-10-2003, 12:53 PM   #5
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
screw the us ej205. if u work at a motorsports shop, u shouldnt be worried about the cali-man appeasement, or what not. JDM all the way. amillion things going for the JDM in advantage performance wise to the USDM, and its cheaper, and its easier to do.
theres a couple other threads with decent discussion and argumentation of the usdm bandwagon as well as the JDM, pop a serch on this forum. basically u want a entire front clip to swap everythign with
h
supermoose is offline   Reply With Quote
Old 12-10-2003, 06:03 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if it is truly a 93, which if its a 2 door it isn't
go for the jdm swap only thing to worry about is emmisions testings ..
get the full car if you can..
Need question answered for doing 1993 Ej22t swap into 1998 impreza Mechkiller31st Pre-2002 Factory Turbo Powertrain 31 09-14-2010 05:56 PM
Wiring job for EJ22T swap into 96 Impreza Old School Scooby North West Impreza Club Forum -- NWIC 12 09-26-2008 08:03 PM
'04 WRX (or STi) seat swaps into GC Impreza Siper2 Subaru Conversions 4 09-06-2006 03:11 PM
Jspec EJ20T swap into 97 Impreza L Murray Engine Management & Tuning 24 11-02-2002 03:20 AM
turbo engine swaps into previous imprezas? dj_dk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-14-2001 10:26 AM
