Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 10-16-2005, 09:41 PM   #76
fatray
Member#: 18150
2002 WRX Wagon EJ207
Velocity Red, Liberal kit
Originally Posted by SolidSnake
My question is will the UTEC give me any better gas mileage? If it does cool and I can use it as an excuse to tell the wifey I am getting it.
-I have a 04' STi, with a TB exhaust, intake, and BOV.
Well the UTEC is supposed to give you more HP. If you get more HP you will get less MPG. That energy has to come from somewhere, that somewhere is gas.
fatray is offline   Reply With Quote
Old 10-16-2005, 09:43 PM   #77
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
disconcur... depending on what map you use, alot of the maps use a more efficient a/f ratio... the cars run pig rich from the factory. i think that will save you some gas mlg.
CarWidow is offline   Reply With Quote
Old 10-27-2005, 06:05 PM   #78
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
Thumbs up nasioc informs Utec newbie...
OMG, even years later, this thread ROCKS. WRX Hackers & Nasioc have TONS of info. Lemme get to reading...
cellobro is offline   Reply With Quote
Old 10-27-2005, 06:23 PM   #79
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by sooshimon
So I've read the Manual about 24 times and been through the forums.
My problem: Uploading maps onto the UTEC. Yes, I am doing transfer -> send text file, pressing enter before i do it and all that. As I try to upload, it'll stop at about 10% and say Checksum Error File Corrupt. I have Version 4.2c
Any other ideas other than the ones already posted on this thread?
http://forums.nasioc.com/forums/showthread.php?t=872292
cdvma is offline   Reply With Quote
Old 12-28-2005, 06:15 PM   #80
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
wrong topic.
steve is offline   Reply With Quote
Old 01-31-2006, 12:24 PM   #81
Bbasso
Member#: 66235
2005 WRX
I need to disagree.
If you keep the weight of the car the same but increase the power of it then the car will have an easier time getting to and keeping speed. I know this because over time I have increased my power while reducing weight and the MPG went up each time I did more inprovements on the ITR (WRX is still stock).
There is a point where you can have too much power and it will decrease the MPG such as a 600+ whp setup in just about anything. But for reality sakes... any of the current day cars most stock or midly modded, we are not going past that point. So increasing MPG while gaining power power is common.
Of Course this is providng the tune of the complete car is on point.
Bbasso is offline   Reply With Quote
Old 01-31-2006, 12:45 PM   #82
Davenow
Member#: 23676
You wanna bet on that? WHile that is usually true, its very often not.
I got 50+ more miles out of a tank of gas at 309whp stage 4 than I did at stock/stage1/2/3, and I know a LOT of stage 4 wrx guys that got better gas milage at stage 4 than they did stock.
My STI also picked up 20+ miles per tank when I went from stock to stage2. And another 20 miles when I added the alcohol injection.
It is entirely possible to make a motor more efficient, and gain power while not losing mpg..
Old 01-31-2006, 12:46 PM   #83
Davenow
Member#: 23676
You saved the maps in word or notepad or something. Or someone did. That will cause that specific error every time.
Old 02-06-2006, 02:46 PM   #84
Freon
Member#: 88322
2009 BMW 135i
A UTEC should have little to no effect on gas mileage when cruising around town, since the UTEC won't be controlling anything.
Gas consumption while beating on your car is pretty irrelevent, IMHO, but in general your power output is going to be closely tied to gas consumption.
The rest is anecdotal and poorly acquired data.
Freon is offline   Reply With Quote
Old 03-16-2006, 10:20 PM   #85
kcook
Member#: 78074
2005 STi
this is a real simple question, but i have the Rev6b utec and i installed it today with the abc. my maps were pre loaded into my utec so i didnt use the laptop to do anything for the install today. my abc is open 3 turns and im hitting 16ish psi by my boost gauge reading. anyway, does the red light in the middle of the utec come on all the time or only when the serial cable is hooked up with a laptop?
kcook is offline   Reply With Quote
Old 03-16-2006, 10:47 PM   #86
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
i believe that is on all the time, however, mine is always under my floorboard so i can't really remember? free bump for others to see
Old 03-16-2006, 11:50 PM   #87
Lost_Pete
Member#: 100570
The red LED is on whenever power is applied to the UTEC. Note that turning off the key does not immediately turn off the power to the ECU and the UTEC.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 04-11-2006, 12:14 PM   #88
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
n00b question: I bought a used UTEC recently. How do I figure out what software rev is currently loaded? I assume I need to hook it up to a computer? I was hoping for a visual clue.
forced4 is offline   Reply With Quote
Old 04-11-2006, 12:46 PM   #89
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
might be easier to get the number off it and contact turbo xs to find out...
Old 04-11-2006, 01:01 PM   #90
Gethin
Member#: 2998
If it's used then the only way to know is to hook it up to a computer and run Hyperterminal, it will show up on the dashboard screen. TurboXS won't keep a record of who's upgraded the firmware
Gethin is offline   Reply With Quote
Old 04-11-2006, 02:15 PM   #91
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Thanks
Old 04-11-2006, 03:42 PM   #92
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
^^^ good point
<--- in the slow group today
Old 04-24-2006, 03:24 PM   #93
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
One more n00b question: How do I check what hardware revision the UTEC is?
Old 04-24-2006, 06:25 PM   #94
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
i thought that one was printed right on the back of the unit????
Old 04-24-2006, 08:22 PM   #95
forced4
Member#: 13304
2002 WRX WRB
De Re Metallica
Found it under a removable cover.
Old 04-24-2006, 09:08 PM   #96
CarWidow
Member#: 81000
2002 WRX Wagon
MBP
sweet
Old 05-04-2006, 11:10 AM   #97
Blind_man
Member#: 113688
ANother Newb question:
Just had an offer to purchase a UTEC ver 2. What is version 2? How many versions are there? and which versions do people prefer?
Blind_man is offline   Reply With Quote
Old 05-13-2006, 05:41 PM   #98
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
subscribes
LIQUIDSK8S is offline   Reply With Quote
Old 05-14-2006, 11:22 PM   #99
Lost_Pete
Member#: 100570
Have a look at this thread;
http://forums.nasioc.com/forums/showthread.php?t=626740
regards
Pete
Old 07-06-2006, 01:00 PM   #100
WrxRick
Member#: 85761
2005 05' STi
so you cant just plug and play the UTEC like an Accessport? Does it use the same port under the dash?
WrxRick is offline   Reply With Quote
FS: (HR) Subaru STi and WRX parts - exhaust, dp, uppipe, FMIC, UTEC, CAI, etc. azrakain MAIC Private Classifieds 71 06-02-2011 08:21 PM
Really Basic UTEC stuff. A little Help Please. Aarondost08 UTEC 2 06-14-2009 01:00 PM
Basic UTEC vs UTEC Delta Unlikely Hero Newbies & FAQs 3 04-25-2008 08:59 PM
Basic UTEC Maps JackClark Engine Management & Tuning 3 09-10-2005 09:44 PM
Sumb Basic UTEC Stage4 Map question Brian Broz Engine Management & Tuning 3 05-06-2004 01:58 AM
