Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 12-10-2003, 06:46 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default Looking into heads for the EJ18 buildup
Alright, I need to hear from people who know the best route to take here. It starts with a simple breakdown: stay SOHC or convert to DOHC.
If I go DOHC, that'd be sweet. Would the EJ20 heads flow better than the EJ25 DOHC heads? The EJ25 duals are pretty hard to find, IIRC. One thing about going with DOHC is, I don't think I would have the money to buy aftermarket cams, so I'd be using the stockers.
If I stick with SOHC, should I convert to a different head or keep the 1.8 head. Thinking straight forward, would the EJ25 SOHC have the best flow? I'd definately be in the market for aftermarket cams if I went this route.
First priority is keeping the cost down. I would love go DOHC and get some sweet cams but that is money that I don't wanna spend. Second priority is durability. I wanna put something in there and not have to worry about my car going back into the garage and pulling the engine again. Lastly, the final priority is performance. Thanks for the help!
Brent
scoobyimprza is offline   Reply With Quote
Old 12-11-2003, 02:51 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I dont think the EJ25 heads will work right with the 1.8 block... That might make a freakin huge difference between the valve space and the piston space that might cause problems. Im still looking into the EJ20T heads on an EJ18 block, ill be getting the heads next friday and then after that experimenting with the fit on a 1.8 block thats sitting around.
If you stay SOHC, actually the best thing to do would be find a MY97 1.8 engine which has a little more power and find out what makes that extra power then use that... Also try using some Legacy EJ22T heads, or even just the cams/valves etc. from that head because its the same design with very little differences but enough that it might make a difference...
Old 12-11-2003, 04:13 AM   #3
Blugin
Member#: 5270
2008 EvoX MR
Red
I read a thread on here a while back that talked about coolant passages not matching up between the EJ18 and newer motors. Might want to check on that.
Blugin is offline   Reply With Quote
Old 12-12-2003, 04:54 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I dealt with that too, and from what I can tell its bogus. The coolan ports are the same on the EJ18 block as the EJ20 block because really its the same design in there exept for the larger bore cylinder walls. IE a EJ20 head will line up in that reguard fine.
The issue that im not too sure about is valve/piston head clearance... Ill find out soon enough hopefully!
Old 12-16-2003, 08:38 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Does anyone know if EJ25 SOHC cams will fit in the 1.8SOHC heads? That'd be a nice way to increase breathing without doing a whole lot of custom work......
Jay Storm
Old 12-16-2003, 08:31 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Jay Storm
No they will not
Old 12-17-2003, 09:50 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
darn.....
Thatd be too easy. Where's the differences? Bearing caps? Valve spacing?
Jay Storm
Looking into HID's for my truck, but will it be safe? sedagive Newbies & FAQs 6 07-29-2009 06:45 PM
BMW looking into applying for state aid Hazdaz Non-Subaru News & Rumors 16 01-24-2009 06:06 PM
13.4 @ 103 for the ej18 turboL Normally Aspirated with bolt-on Forced Induction Powertrain 360 12-04-2007 03:18 PM
Looking into heading to Myrtle Beach next month... bhamwrxman South East Region Forum 1 07-20-2005 04:45 PM
Anyone heard of Vtech (like) Cylinder Heads for the EJ25? Check out the link. MY99 2.5GT Normally Aspirated Powertrain 1 08-20-2001 02:24 PM
