Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 12-10-2003, 10:32 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default OB Specific info on Fog Light/High Beam mod
I recently installed Hella 500's in the factory fog location and just spliced the power into the stock wiring. How can I modify my wiring to allow the fogs to be on independently of any other lights while still using the factory switch? I've found several articles on Scoobymods.com which explain how to do this in an Impreza, but I've taken apart my dash and the wiring seems to be different. Has anyone done this?
whtlegacy is offline   Reply With Quote
Old 12-20-2003, 02:29 PM   #2
BajaGirl
Member#: 24617
I've been trying to find this out for ages myself. Its almost like nobody has ever done it. Whenever i ask people point me to the instructions for the impreza. That doesnt help because they are wired a little different.
BajaGirl is offline   Reply With Quote
Old 12-20-2003, 05:19 PM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I ended up rewiring them so they're hardwired in. I couldn't come up with an answer either.
Old 12-22-2003, 05:47 AM   #4
OhBe1
Member#: 45760
06 LOB5MT,LGTbits
OB
I've been planning this aslo, but not done yet. I think the Haynes manual diagram may actually be correct on this one, althought the wire colors may be wrong. If it is correct:
Power to the switch & relay coil come from the right headlight fuse. The switch then grounds thru the combo switch low beams. So it's triply connected to the low beams.
Even if the Haynes colors are right, the problems are finding which two of the three black/yellow wires go to the relay and the switch, and finding the relay itself.
The yellow/blue ground from the switch just needs to be cut & then grounded anywhere. The input to the switch & relay coil need to be cut & connected to the running lights. But first you gotta find the relay. It's deeply hidden in the footwell, behind other relays & remote door lock electrics. Bypassing it with a new relay may be easier. And probably mandatory if the new fogs are high-wattage.
I've given up finding the relay twice now. But the weather might be warm enough next weekend for another attempt.
OhBe1 is offline   Reply With Quote
Old 12-22-2003, 04:53 PM   #5
rammer
Member#: 51074
2005 Outback XT
Obsidian
Is it pretty easy to swap the Hellas in? Are they fogs or driving lamps? I'm pretty interested in upgrading those lights soon.
Dave
rammer is offline   Reply With Quote
Old 12-22-2003, 05:42 PM   #6
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Lots of writeups in here, do a search on hella 500 (I know I've posted it at least 3 times )
sybir is offline   Reply With Quote
Old 12-23-2003, 05:33 AM   #7
OhBe1
Member#: 45760
06 LOB5MT,LGTbits
OB
Saw the 9/23 & following writeups, but uses the stock wiring logic.
Old 12-23-2003, 09:49 AM   #8
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
Yeah, I used the stock wiring logic (but relayed, for clean power).
I was referring to the physical mounting directions for rammer.
Now that I think about it, though, I'm not sure 500's will fit int he BH cars......
Old 01-06-2004, 09:51 PM   #9
Caucazian
Member#: 51025
2004 Impreza OBS
WR Blue
I jes got one question. My fogs are projectors is their anyway to upgrade them seeing as how my car is an 04?
Caucazian is offline   Reply With Quote
Old 01-06-2004, 09:59 PM   #10
mmmprza
Member#: 45778
2001 Aspen White GC8
Who made my hoodScoop
took me awhile to figure it out myself. blew about 10 fuses and alot of headaches... but i mastered it.
i'll take apart my dash tonite and tell what color the wires are i taped into!
i also have a pair of IPF fog lights in the middle, they are on the same switch... it's a 3-way toggle switch i bought from subaru, it looks factory!!
mmmprza is offline   Reply With Quote
Old 01-13-2004, 08:41 PM   #11
billybob3
Member#: 42727
That looks sweet!
billybob3 is offline   Reply With Quote
Old 01-15-2004, 06:36 AM   #12
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 01-22-2004, 09:28 PM   #13
BajaGirl
Member#: 24617
How about 2000 MY and up OB/Baja? Is the wiring the same?
Old 01-23-2004, 02:26 AM   #14
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
any info on what color wires to tap yet?
Old 01-23-2004, 08:03 PM   #15
BajaGirl
Member#: 24617
TTT
Old 08-15-2009, 08:25 PM   #16
gifters
Member#: 119762
2003 Subaru Baja
Black/Silver
What happened to the instructions
gifters is offline   Reply With Quote
Fog light + High beam Jerry Interior & Exterior Modification 1 08-17-2001 06:22 AM
Fog Light with High Beam mod documented! 8Complex General Forum Archive 13 03-19-2001 03:23 PM
i did MY00 RS fog light with High beam mod joostin420 Technical Forum Archive 8 06-20-2000 04:53 AM
any updates on fog lights on with high beams? joostin420 Technical Forum Archive 8 06-13-2000 02:03 PM
Who posted the fog light w/high beam mod wiring diagram last week??? joostin420 General Forum Archive 4 06-06-2000 12:34 AM
