Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 12-11-2003, 12:39 AM   #1
blackbok
Member#: 12176
2002 Geo Metro
Teal
Default COBB silacone hose replacement
Anyone have the problems I'm having w/ the silacone hose that runs off of your COBB (or other I suppose) intake? I'm talking about the 3 blue (or red or whatever other color you may have) hoses.
I recently had to take my COBB off and put the stock airbox back for warranty work. Well upon going to put it back on, I noticed that two of the hoses (the ones that attatch ove the spark plugs) were pretty dark and fragile looking from the heat. So I went out and bought the same hose at a local shop. Same diameter. Upon manhandling the hoses back on their respective receptors, splitsville. The stuff was so delicate, the slightest wrong angle would create a small tear which if pushed would split up the length of the hose. Man this stuff is delicate! Quite annoying as I hunched over my engine, slowly snipping away the precious lenths of hose I needed to hook up. I finally got them all on. But to tell you the truth, I am not comfortable with those hoses. After having my COBB on only a few months after buying it, one of the connections had split as a result of heat.
So, all of that just for this... Is there a more durable alternative that someone else has used? I am assuming that as long as it is a hose ( of the same diameter) to get air form the intake into the engine, it doesn't matter what type it is. Would standard black engine hose or something of the sort do OK? Just want to be sure I'm not overlooking something important.
Thanks!
blackbok is offline   Reply With Quote
Old 12-11-2003, 11:06 AM   #2
BlackAndBlue
Member#: 40617
Call up Cobb and let em know whats up, they'll help ya out
BlackAndBlue is offline   Reply With Quote
Old 12-11-2003, 11:52 AM   #3
jeffg
Member#: 2958
2001 WRX (GC8)
My hoses look the same way. They turned dark, but only the ones coming from the crankcase vents. The hose from the PCV looks fine.
I have notices that a lot of people are using the clear reinforced hose from home depot for thier oil catch cans. This hose would probably work for the CAI as well.
J
jeffg is offline   Reply With Quote
Old 12-11-2003, 01:20 PM   #4
blackbok
Member#: 12176
2002 Geo Metro
Teal
What about just using rubber fuel line? Any drawbacks/problems with that?
Old 12-11-2003, 04:25 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've had no problems with my Cobb hoses and I bought my CAI on the first group buy Trey did here over 3 years ago. But I have also heard a rumour they changed hose vendors. Don't know if there is any truth to that, however. Call them up and talk to them about it. They are very customer oriented and will likely take care of you. And they are always looking for feedback, good or bad...
Old 12-12-2003, 01:32 AM   #6
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Not to hi-jack the thread but what about the black part the filter is in? mine is cracked so would I call Cobb or PDM, I am selling the car this month but I don't want to sell it in anything less than perfect condition.
Poppa smurf is offline   Reply With Quote
Fuel filler hose replacement Meat Supply Interior & Exterior Modification 2 04-01-2007 09:48 AM
GC8 rad hose replacements STinger Subaru Conversions 7 06-05-2006 04:12 PM
Boost gauge/bov hose replacement? forsaken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-31-2005 09:23 AM
Local shop that sells silacone hose? blackbok Southern California Impreza Club Forum -- SCIC 10 12-01-2003 02:54 PM
oil return hose replacement jdchmiel Normally Aspirated with bolt-on Forced Induction Powertrain 3 06-28-2001 04:55 PM
