06-27-2000, 05:30 AM | #1 |
Member#: 1342
Vehicle:99 OBS & SUXASS May your line be smooth |
Locking Fuel Door?
Has anyone noticed existing hardware for a locking fuel door in their RS? Anyone tried to utilize it? I am worried that someone has stolen gas from my car last night. The only problem was that it was at about an 1/8th of a tank last night and this morning the low fuel light was on and stayed on.
06-27-2000, 06:30 AM | #2 |
Member#: 1055
Vehicle:2005 No legacy for u It's a diesel |
Bug:
I wouldn't be overly concerned with your change in gas gauge level. Sometimes when my tank is low (and I know the light should be on) it won't come on until I turn off and restart the car. I sometimes get a similar small discrepancy in the fuel level. When I turn the car off it is just above the E line but when I restart, the light is on and the needle is almost below the line. I just don't think the bob in the tank is very sensitive at the lower levels. This is typical as most tank bobs float on a shaft and travel in an arc shape. This makes the bob travel quicker through the middle of the range then at the extremes (ie the needle takes forever to drop from F and is slow to approach E. As for locking... A friend of mine gave me a nice locking gas cap. I would check with any autoparts store and see what they have in stock. Mine is great with absolutely none of the dreaded OBDII Check Engine lights for a loose cap. Good luck, Kyle PS- As a side note to this, from what I can tell some foreign Imprezas have "pull to release" gas covers. These are easy to spot as they do not have the little tab in the cover to stick your finger under. |
06-27-2000, 06:38 AM | #3 |
Member#: 1342
Yeah, I thought about a locking cap. Man, the only thing I really miss about my old '93 escort was that no one could get to the gas tank. I actually did encounter an incident in my neighborhood a couple years ago when I was driving a huge station wagon. No one drove the car but me, I was the only one with keys. I filled up the car and drove it about 50 miles. The next morning the tank was on E. Very disturbing. I live in such a nice neighborhood too.
06-27-2000, 08:02 AM | #4 |
Member#: 935
Vehicle:Will Woollard Fan Club |
Oddly enough, Imprezas in Europe seem to have the gas flap open from within the car, as do L model Imprezas here. I just think they're copying BMW, 'cause I can't think of many Japanese cars that have manual gas tank access these days, or a least a lock on the flap.
06-27-2000, 11:19 AM | #5 |
Member#: 1392
does anyone know of a fitting replacement cap that locks?
dave. |
06-27-2000, 02:33 PM | #6 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
If you get the lever that goes on the floor inside the car from an Outback or an earlier Impreza and the cable, you can make your gas door lock too. The actual "lock" is behind the black plastic in the gas fill area, and all you have to do other than that is pull the plastic clip off the door, and you're done. If you can find the part numbers, you can get all that stuff brand new from a Subaru Dealership.
06-27-2000, 02:47 PM | #7 |
Member#: 935
Sam, that's pretty cool. Form just looking at the cap you'd swear it's just as easy to access as the cap on a pickup truck.
Has anyone done the conversion for the RS? That would make a good addition to the modifications section along with the trunk light. |
06-27-2000, 04:12 PM | #8 |
Member#: 379
I have a locking cap, I tryed my wifes gas cap off of her dodge mini-van and it fit. So I went to checkers and got a gas cap for a 97 dodge caravan. It works and I havent had any problems now for over a year.
06-27-2000, 08:35 PM | #9 |
Miss You Mom
NESIC
Parts are ordered- will post on my website sometime before frogs rule the earth again.
http://members.xoom.com/_XMCM/northursalia/ |
06-28-2000, 12:56 AM | #10 |
Member#: 598
Yotsuya:
the bmw's do lock when you lock your doors...i checked on my friends 328i it only opens when you unlock your doors. |
06-28-2000, 05:56 AM | #11 |
Member#: 1342
Thanks North Ursalia! Exactly what I wanted to hear! Where did you order the parts and how can I get them??
[This message has been edited by BugBomb (edited June 28, 2000).] |
06-28-2000, 04:03 PM | #12 |
Miss You Mom
NESIC
You can get them at any dealer (the earlier Impreza model parts I'm told will fit) and that's what I ordered. You're going to have to get friendly with the parts guy and go through the huge book o' part numbers to get the part #'s (wish I could find what I did with the numbers...)
06-28-2000, 09:14 PM | #13 |
Member#: 188
Vehicle:2004 Forester XT 24k gold on white |
I have a remote gas door in my MY00 RS. That's what happens when you need the quarter panel replaced.
nizz |
06-28-2000, 09:14 PM | #14 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
BugBomb, what would happen if you removed that little black tab and closed the door. Would the white plastic piece get into the hole and lock it. Or would it just hit the side. If it did lock like that, how would you open it.
06-28-2000, 09:16 PM | #15 |
Member#: 1581
06-29-2000, 04:48 AM | #16 |
Member#: 242
Vehicle:MY05 PSM GGA !STOCK MY99 RS-RIP / MY95 MX-5 |
Part #s should arrive with the parts. Keep up the good work.
06-29-2000, 07:33 AM | #17 |
Member#: 58
Vehicle:04 STi (blue/gold) 98 2.5RS Turbo (sold) |
Check the STi M-List archives. Someone (Joel? ) successfully found all the parts and part numbers for the remote gas door.
I think the biggest hassle was you need to paint a new gas door (it's flat without the finger hook), or do a significant mod to your current gas door to get it to work. |
06-29-2000, 10:38 AM | #18 |
Member#: 1342
Well, if the stock door will lock, what would it matter if it had that little notch? Could you still pry it open easily?
06-29-2000, 09:35 PM | #19 |
Member#: 1581
No it would be locked, as if it were a car with a locking door, so it would be like trying to open the door on a locking car.
WTB: 03 Passenger Door handle/lock & door? | nam | Private 'Wanted' Classifieds | 1 | 09-11-2008 02:46 PM |
Jun exhaust manifold, GC8 folding door mirrors, 1994 WRX cluster, flat fuel door | keirnna | 1993 - 2001 Impreza Specific Parts | 14 | 06-02-2008 06:57 PM |
EJ20G Radiator Brackets and Plastic Locking Fuel door | keirnna | 1993 - 2001 Impreza Specific Parts | 0 | 04-29-2008 07:49 PM |
locking flat fuel door | henryh | Vancouver Impreza Club Forum -- VIC | 2 | 07-05-2004 06:52 PM |
Conversion from 99 fuel door to the "flat fuel door" | 99Impreza_OBS | Normally Aspirated Powertrain | 4 | 04-13-2004 11:56 PM |
