Old 12-11-2003, 12:45 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Has anyone swapped a 5mt into a 4EAT EJ25?
I know KhaOs has done this on his WRX and the webmaster of LegacyCentral.org did it with his turbo BD but has anyone swapped a 5mt into their 4EAT EJ25? I've been itching to swap a 2.5rs 5 speed into my '99 Legacy and I've now got the better part of my $2000 parts budget together. Anyway, I'm on the lookout for parts at this point. I've talked with the owner of legacycentral.org who has this process well documented from his manual swap into his '93 Legacy w/ Turbo conversion. Here's his writeup
So far, here's what I think I need:
Transmission
Clutch
Flywheel
Pressure plate
Pilot Bearing
Throw-out Bearing
Driveshaft
Shifter assembly
Pedal assembly, (brake & clutch)
Clutch master and slave cylinder
Hydraulic clutch line
Starter Motor
3-piece rear crossmember
I've been told that on the EJ25, the MT and AT ECU's are different. Can anyone confirm this?
Any ideas at this point?
whtlegacy is offline   Reply With Quote
Old 12-11-2003, 05:58 PM   #2
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Default I'm slowly converting my SVX
OK, very slowly.
ECU is not a factor in my swap. Remove the TCU (trans) and you're good to go.
Good luck with your swap.
Once more thing you may need would be the rear diff to match the transmission gear ratios. Mis-matched ratios are bad news!
Todd
wawazat is offline   Reply With Quote
Old 12-12-2003, 12:34 AM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
That's good to know. Subaruparts.com seems to have different ECU's for manual and auto EJ25's. Could it be possible that these are the same and I just have to enable/disable something on my existing ECU?
Old 12-12-2003, 10:18 AM   #4
Boost4U
Member#: 16459
1998 2.5RS
I'm working on it in my RS....WRX 5MT into 4EAT RS. I have all the mechanical hooked up, revese ligths work, brake lights work. I'm going to be running a Tec-2 standalone ECU. Running the stock ECU you will most likely have to wire in the neutral position switch and you will need the MT ECU(they are different). Another thing is that you will have issues running ABS, your 4EAT has a TCU(Transmision Control Unit) and there are several systems that are wired differently in MT vs AT, 1) ABS, 2) Reverse lights...the brake lights seem to work fine without the TCU, and I have seen a post where the guy had got his ABS working I believe....Not a priority for me now..lol Hope this helps...your mechanical parts list looks about right
-Boost
Boost4U is offline   Reply With Quote
Old 12-12-2003, 08:35 PM   #5
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Boost,
So it sounds like I should add the MT ECU to my list. Any idea who this could be who wired up his ABS?
Old 12-24-2003, 03:23 PM   #6
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
just to let you know ive got everypart needed for you swap(other then the pedals and ecu)
near everything youd expect is aftermarket and very high quality(sti, act, jun) the trans was rebuilt less than 3,000 miles ago and i live near pittsburgh so you can come see it in person and not have to pay shipping
let me know if your interested
mike
kaneda3 is offline   Reply With Quote
Old 12-24-2003, 11:23 PM   #7
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
pmed you
Old 12-25-2003, 09:47 AM   #8
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
I haven't thought about this for a week or so as I just spent a lot of money on a header-back exhaust. However, it sounds like Sybir is about to start the swap on his 4eat Legacy Outback, so that's promising to hear.
I'm wondering what I should look for in used parts? Is the only real wear part the clutch? Should I worry about pulling a junk-yard transmission if I'm planning to replace the clutch anyway? What else could possibly be abused?
Old 12-26-2003, 01:04 PM   #9
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The ECUs may have different part nuimbers, but I'm running an AT ECU, and, with the addition of a single pin to the wiring harness to ground, the ECU stopped looking for the TCU, and instead occasionally informs me of a failed neutral position switch (which isn't even hooked up).
So, at least, on the WRX, you don't need a different ECU.
/Andrew
Kha0S is offline   Reply With Quote
Old 12-26-2003, 05:16 PM   #10
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
in a legacy, you cant just throw in a MT ecu into a car that came with an auto.
they have a few different pin locations. MAF sensor pin is different. and a few other minor things.
keep the ecu that you have.
subiekid is offline   Reply With Quote
Has anyone done 5x114.3 wth a 4eat? Solinari Transmission (AT/MT) & Driveline 0 07-30-2007 04:58 PM
Has anyone swapped an EJ25T into an older Legacy ? Legacy Subaru Conversions 7 03-18-2005 10:22 PM
Has anyone swapped out their 04 WRX carpet with a STi carpet Scoobie Newbie Interior & Exterior Modification 25 05-05-2004 04:36 AM
Greddy Turbo Timers...has anyone programmed a song into your yet? jdmimpreza Electrical & Lighting 0 03-04-2003 05:28 PM
Steering ratio on regular STi Ver. VI? Has anyone fit RHD rack into LHD car? garface Brakes, Steering & Suspension 1 02-05-2003 04:40 PM
