Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 12-11-2003, 02:38 PM   #1
RidinLow
Member#: 329
1995 325i
Arctic Gray
Question impreza shocks?
Can I use GC8 or WRX wagon shocks on my '97 OB? I plan on keeping the OB springs but I wanted to replace the struts because they've got 100k mi on them.
Thanks!
RidinLow is offline   Reply With Quote
Old 12-25-2003, 02:25 PM   #2
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
they'll probably be way underdamped but i _think_ they would fit OK
whtlegacy is offline   Reply With Quote
Old 12-25-2003, 04:52 PM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
WRX wagon or sedan units should work OK.
IIRC, somebody with a 99 OB used WRX lowering springs on his stock shocks, and the only thing he had to change was rear top mounts; since you'd be keeping stock springs, you should be fine.
It's an odd data point, but I'll be putting a full hybrid Ground Control/WRX setup on my car in the next few days; WRX stock struts, WRX hats, and GC sleeve kit meant for a WRX wagon, with bumped rates in the rear.
I'll let everybody know how it rides; I didn't have enough $$ for AGX's, and the GR2's are a waste if you're lowering the car much, as they're not that much firmer than stock, and seem to blow easily. The nearly-new WRX units should be an OK compromise. Remember, a good portion of Subaru OEM dampers are built by KYB, so they're not innately poor just becuase they're OEM. I've ridden in a BF wagon with the same setup as my car is going to have, with 15k on the setup, and it doesn't seem underdamped, because high spring rates keep it taught enough that it doesn't bounce much.
sybir is offline   Reply With Quote
Old 12-25-2003, 11:10 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Actually, WRX wagon struts wouldn't be underdamped because a WRX wagon is actually within a few pounds of the 1st gen OB's.
So would using WRX wagon struts lower the car any? I'd like to keep the high ride height.
Old 12-25-2003, 11:34 PM   #5
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
They'll lower the car ~40mm, by all accounts. They seem to be the same *general* layout as L/GT stuff, as opposed to OB height. I'd go for it if you can handle a mild drop, but not if you want to stay at stock height. You will also no longer be able to run OB wheels and tires, as, especially in the rear, you'll rub on the new, lower-mounted spring perches due to the taller tires.
Old 12-25-2003, 11:50 PM   #6
RidinLow
Member#: 329
1995 325i
Arctic Gray
Old 12-26-2003, 12:42 AM   #7
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
I know, it sucks
Remember, GR2's *are* available in stock OB configuration, so all is not lost, just a hair more expensive than WRX takeoffs. I've seen sets for ~300 though, and that's not much more than some WRX takeoffs, which go for $200 or so. I lucked out on mine, and got them for $75 with hats, so my swap is gonna be easy.
The GR2's are probably your best bet, then you're getting brand spanking new shocks, too......
Old 01-15-2004, 06:49 AM   #8
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
they look awesome too
Rally Medic is offline   Reply With Quote
Old 01-15-2004, 08:45 AM   #9
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Would the Koni yellow inserts be worth doing for the OBS? What springs would go well with Konis for minimal (say 1" +/- a little) lowering?
1 Lucky Texan is offline   Reply With Quote
02 impreza headlight wiring issue garinhash Electrical & Lighting 4 06-02-2010 12:49 PM
OEM 02 Impreza Shocks and Springs - Got Everything Cheap Cky47 Suspension/Brakes/Handling 9 12-02-2007 08:58 PM
'06 Impreza Shock sensor Lorenzo Car Audio, Video & Security 50 06-23-2006 01:18 PM
Legacy to impreza shocks? Tbird Man Subaru Conversions 11 05-08-2005 10:52 PM
solution found: impreza electro static shock lstepnio General Community 72 03-11-2002 12:14 AM
