Old 12-11-2003, 06:28 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Default help with the starter on an ej20g swap
ok...so i'm not understanding why this darn starter won't kick over. the battery is full, the starter is grounded...all the connections are clean and secure. but when i turn the key all i get is the click from under the dash board. i'm not understanding. i've plugged the jdm ecu onto the back of the starter with that little pin, no go, unplugged it, no go, plugged in whatever was supposed to be there stock and it still won't kick over? if you've done this swap please help and i hope you can understand what i'm talking about...i'm a little frustrated. thanks in advance.
-eric
smacksube is offline   Reply With Quote
Old 12-11-2003, 10:13 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Does the engine turn freely if you use a socket and rachet?
Ver.III is offline   Reply With Quote
Old 12-11-2003, 10:30 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
if it does turn freely with a socket and rachet I'm not sure if this would work with an AWDrivetrain but u could try to pop in the clutch have it in 1st hold the clutch push the car as fast as u can let in teh clutch and turn it to get it going worked for my brothers prelude but thats fwd
scobaru is offline   Reply With Quote
Old 12-11-2003, 11:32 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Check that the engine spins freely as Ver III has said. If it does spin, then your next step is to pull the starter and have it tested. You can just take it to Autozone or something. If it doesn't test out properly I have an extra starter, hehe. If it does test ok then your wiring is suspect and start tracing wires.
-Jon
Old 12-13-2003, 03:35 AM   #5
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
check the back of sth starter if the bolt is in and the little plug thingybob is in. we forgot that guy, the tab thing so it wouldnt start and we push started for the longest time. haha
nar.
supermoose is offline   Reply With Quote
Old 12-13-2003, 10:20 AM   #6
Structure828
Member#: 50488
1999 GC8 ej20g!
Call me. I want to know if you got ahold of the other starter
This no car thing is making me go nuts. I probobly forgot how to friggin drive 5 speed by now
Structure828 is offline   Reply With Quote
Help with Cruise Control on an STI swap pezcore Interior & Exterior Modification 20 05-10-2010 02:17 PM
Need Help with the Starter wrxguy243 Newbies & FAQs 3 12-02-2007 05:31 PM
WRX harness through the firewall on an RS swap Zephyr Subaru Conversions 3 12-06-2003 09:26 PM
Help with speed sensor on engine EJ20 swap Homemade WRX Subaru Conversions 11 09-29-2003 11:38 PM
Need some help with Rear sway on an L... Subi Ru Mid West Subaru Owners Club Forum -- MWSOC 5 04-09-2003 01:42 PM
