Old 12-11-2003, 08:42 PM   #1
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
Default Cool info on spark plug gap
http://www.se-r.net/engine/platinum_copper_ngk.html
I found this while looking for info on spark plug gaps. I have a 1998 Legacy 2.5GT and changed the plugs from the plats that they come with stock to NGK coppers (BKR5E-11) Now I was wondering about the gap of the coppers should it be wider?should it be narrower?
According to this site when going from coppers to plats you should wider the gap. Does that mean when I switched from plats to copper I should have made the gap smaller?
I'm running them right now gapped at 0.041 in. The manuel calls for 0.039 to 0.043 in for the stock plats.
White2.5GT is offline   Reply With Quote
Old 12-12-2003, 10:13 AM   #2
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
nobody has any clue about this stuff?
Old 12-12-2003, 10:29 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Run what your manual says.
I wouldn't put a whole lot of confidence in that page.
Legacy777 is offline   Reply With Quote
Old 12-12-2003, 10:49 AM   #4
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
I'm not sure where they got that idea. For example, the 1999 Impreza owner's manual has multiple plugs listed (incl. both copper and platinum plugs) but only one gap spec range.
Shane -- http://www.warpthree.com
Warp3 is offline   Reply With Quote
Old 12-12-2003, 11:12 AM   #5
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
If you use a higher octane (burns slow) 89, 91 ect... would you benifit from increasing your gap a little? would it expose more flame to the mixture, and increase the burn efficency?
Old 12-12-2003, 03:36 PM   #6
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Default spark plug-related question....
Hey, anybody ever heard of indexing your spark plugs? Anyone ever tried it? Does it help? I read about it in HCI. Here's what it says: "Using a marker, mark the porcelain inline with the electrode. Screw the plug in the head and tighten. Make sure the mark aligns the way you want the opening of the electrode to face, favoring the intake valve."
bongchild is offline   Reply With Quote
Old 12-12-2003, 05:39 PM   #7
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
sounds like too much hassle for not enough results. EJ engine have hemispheric combustion chamber, not those overhead valves head wich have some kind of squarry combustion chamber with egdes that induce detonation
NicEJ25 is offline   Reply With Quote
Old 12-12-2003, 10:30 PM   #8
Legacy777
Member#: 4800
just gap the plugs to engine spec and stick them in......anything more and you're wasting your time.
Old 12-13-2003, 03:41 AM   #9
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
Yay, I get to flex my nerd engineer skills again
I'm not sure where that guy in the link get's all his information from, and I wouldn't put a lot of faith in it.
First thing you want to know about fire is quenching. This happens when there are too many cold things around the flame that take away heat. When that happens your flame goes out because there isn't enough heat to ignite the surround mixture.
The second thing to know about flames, and probably more applicable to minimum spark plug gap is flame thickness. It's a little hard to explain (and understand), but the flame also needs to be a certain size before it can propagate. If you have a netting with holes below a certain size, the flame can't escape from it (these are called flame holders).
So that said, there is a minimum gap that is needed for a spark plug. If you make it too small, then you can't get a good flame going. Make it too big and you waste more energy trying to get the spark to jump across the gap.
Any other combustion engineers out there that can back me or poke holes in my arguement?
DoorKnob is offline   Reply With Quote
Spark plug gap on PFR7G. wrong or not? Tork1 Service & Maintenance 12 12-18-2010 10:17 PM
9.5:1compression+3076 on E85=Tighter spark plug gaps TDagen Built Motor Discussion 54 07-16-2009 02:40 PM
Has anyone checked spark plug gap on an 03 ursmother Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-09-2005 08:15 AM
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 10:49 PM
Spark Plug Gap on Denso Iridiums TCENGEL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-09-2001 11:47 AM
