#226 |
Member#: 204274
Vehicle:2005 WRX Silver |
Hi guys,
yzp123, the ECU measures the air passing through the airflow meter, and injects fuel for that measurement. When the BOV opens and vents the air to atmosphere, fuel continues to go into the engine (because the injectors are downstream of the throttle butterfly) but not the air. If you data log the airflow meter output during a gearshift, with a recirc valve you see the signal drop immediately upon closing the throttle, and with a valve venting to atmosphere you see the output taper down more slowly, so during the shift fuel is being injected. Now, here's the thing. Is it really a problem? Not really. The throttle is shut, the engine is not under load when this is occurring - the engine is not operating under conditions where changes to the AFR will cause mechanical damage. If the valve is venting too much air to atmosphere, then there will be proportionally more fuel, to the point where backfiring may take place. This of course is best avoided, and can be controlled simply by controlling how much air escapes to atmosphere. So, what are the common compaints against atmo BOVs? Stalling, backfiring, more fuel use, hurting performance, engine damage, etc etc.Well, let's address these issues: Stalling is caused simply by having the valve open too long so that air is still escaping to atmosphere when the car drops into closed-loop idle. The solution is simply to adjust the spring pre-load so that the valve shuts before the revs drop back to about 1200RPM so it can settle into a nice smooth idle. Backfiring is usually caused by venting too much air to atmosphere. There is more to this as other things can affect whether a car backfires readily or not including ignition timing. The solution in most cases is to increase spring pre-load or reduce the ratio of air vented to atmosphere vs recirc (can only be done on valves that allow this adjustment). Excessive fuel usage is directly related to how much air escapes. A BOV can only cause fuel to be consumed (where it wouldn’t normally) when it vents. Now think about the percentage of time that a BOV vents for compared to how long you drive your car for. Unless you are on a race track, you would be doing very well to set the BOV off for any more than a fraction of a percent of the total driving time, and therefore the amount of extra fuel you use would be absolutely negligible and un-measurable. In fact if you got the car on boost just once more than you usually do on a trip you’d use more fuel than a BOV would be responsible for.[/font][/color] Performance – since the BOV can only affect AFR for the time that it is venting, and it will only vent when the throttle is closed or mostly closed, it will have absolutely no negative effect on power or AFRs under load. Engine damage – nope. You’d have to do something very, very wrong with a BOV to cause engine damage, to the point where the car wouldn’t run long enough to cause damage. Taking the BOV apart and feeding it piece by piece into the turbo intake, well, that’s a different story, but that’s about the only way a BOV could cause engine damage. Ok, I’m sure there are people out there who have had bad experiences with atmo-venting BOVs causing all kinds of problems. I whole-heartedly believe however that in the vast majority of cases (some mods and combinations of mods can make a car more sensitive than usual) Subarus will run without issue with a correctly set-up atmo venting valve, and I’m more than happy to discuss any of these issues or topics further, relating to our BOVs or others. Cheers, GFB Pete
Last edited by GoFastBits; 01-13-2011 at 11:34 PM. Reason: Removed font/colour html code from post |
#227 | |
Member#: 157348
South East
Vehicle:high impact sexual violence |
#228 |
Member#: 259591
Vehicle:2011 WRX sedan WR Blue |
#229 |
Member#: 268429
NESIC
Vehicle:2004 WRX PSM |
Great info, just what I was looking for. Had a few people tell me stock holds up just as well as aftermarket when going to stage 2. Have a turbo XS recirculated but guess I will stay with stock until I get my WRX pushing some serious horse.
#230 |
Member#: 281277
SCIC
Vehicle:2006 WRX Silver Metallic |
Who knew a bov could be such a hazard on a car but I guess with a proper tune, it can decrease the strain that it causes.
#231 |
Member#: 182831
SWIC
Vehicle:2009 Subaru WRX Dark Gray Metallic |
I am gonna bring this back to life.. But only for a quick question.. I am pretty sure Im leaking from my stock bypass valve(09wrx).. I wanted to upgrade to the forge recirculating valve and wanted to know if i should get tuned for it.. I only ask due to the fact I wouldnt be modifying the AFR... Or would I? Sorry for the noobness hah..
#232 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
no. a bov is a bov. you dont need a tune for one, it cant be "tuned" get a good one and hope you can deal with potentially stalling out sometimes. my friends running full VTA on his car with zero problems what so ever.
#233 |
Member#: 182831
SWIC
thats interesting.. I was told if you change to vta that you need to tune for it.. Thanks
#234 |
Member#: 265405
Vehicle:2011 WRX White |
#235 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
#236 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
#237 | |
Member#: 250152
#238 |
Member#: 51961
RMIC
Correct. I don't know the exact RPM they turn back on, but it's somewhere around 1500-2000
#239 |
Member#: 285875
thank you very much, answered many of my questions
#240 |
Member#: 282638
RMIC
Vehicle:2002 WRX/STi WRB |
Ok, i haz couple questions too
![]() So, i have a Forge BOV (came with the car/never took it off) i wouldnt mind a stock unit, from what i have read here i might just let go of the BOV. Anyway, its always worked fine, even after i got tuned. Recently my blow off seems to be venting with a long extended "CHUSHHhhhhhhhhhhh" at very low RPMS (its never done this before) so i took it to my mechanic over at 5250 performance in Longmont, CO. There we desided to smoke test to check for any kind of leak within the TI hose. No leak. Next i took him for a drive, he noticed that my BOV was venting dramitically at low RPMS so then we came to a conclusion that my BOV might have "failed" My question is. - Can a BOV "Fail"? does the spring inside go bad orrrr? - Can i replace the internals of the BOV orr should i just buy a new BPV. - *(took out question via editing)* i just cant figure out why its venting so looooooong like. Any ideas? ![]() P.s. let me know if you need any more information ill do the best to describe it. Last edited by 5280HybridXT; 09-14-2011 at 05:05 PM. Reason: Figured out one of my own questions |
#241 |
Member#: 51961
RMIC
Any internal failure I could think of would keep the BOV from opening at all (or it would at least open late). Maybe the spring broke? Or the seat for the spring broke? It's odd for sure. What kind of boost are you running and what car do you drive?
#242 |
Member#: 282638
RMIC
2002 hybrid WRX, 18GXT
it just doesnt sound right at all, ill be in first gear slowly going up to 3000RPMS;shift; then i get a *shuuuuuuuuuuuuuushhhhh* gears 1-5. im stumped. ![]() Its starting to worry me, idk what to do next. *sorry i forgot to add that im running low boost at 17psi and what are some symptoms if the "Spring seat" broke. have you ever ran into something like that? Last edited by 5280HybridXT; 09-14-2011 at 05:40 PM. |
#243 |
Member#: 282638
RMIC
P.s. What could cause the spring to actually break?
So as i drove home from work i listened closely for i can describe it better to you guys, it almost sounds like when it starts to vent, it stays open. could this be true? or am i crazy? ![]() |
#244 | |
Member#: 51961
RMIC
However, the OEM BPV is perfectly suitable for your car with your boost target. Since you can generally pick up a used one for about $30, I'd try that first, since switching to recirc would be a good idea regardless of whether this BOV is functioning correctly or not. |
#245 |
Member#: 282638
RMIC
Okay, ill pick up a stock BPV.
now what if i was planning on going over 400+hp? Im really uncomfortable driving it around when its doing this, i wish someone knew what i was talking about. would it help if i recorded a video? |
#246 |
Member#: 51961
RMIC
Possibly.
The thing is, the bov opening excessively when you let off the throttle at low boost isn't a bad thing, in fact as long as is staying shut when youre on the throttle it's a good thing. You WANT the bov/bpv to open as much as possible for as long as possible when you let off the throttle, without it opening while in boost. The problem isn't that it's opening excessively, it's that you're running an atmo BOV with a draw through maf, and the odd thing is that it apparently wasn't doing it before. |
#247 |
Member#: 282638
RMIC
how could i test if it is opening while in boost?
& yeah im confused as of why all of a sudden it just started to do this out of no where. what a bummer haha, when i boost it, my gauge reads that its holding pretty steady at 17psi, i dont feel much loss in power....just very skeptical about the whole situation, like something COULD go wrong since this whole thing is already pretty sketch. you know what i mean? ill record a video once i get my IC back on, i had to replace the elbow hose because it kept popping off ![]() thanks a lot for the help, i really appreciate it. Last edited by 5280HybridXT; 09-15-2011 at 03:26 PM. |
#248 |
Member#: 290425
SCIC
Vehicle:2004 WAGON/SRT4 NEON PSM |
Hey guys just bought my car the guy I bought it from opened up the oem blow off valve were to its atmospheric! Is that gonna harm the car he plugged the recircuitlotory hose!!
#249 |
Member#: 148110
E. Canada
Vehicle:2005 Legacy GT OBP |
Just to clarify something. The plastic BPV came out in 05+ on the Turbo Legacy/Outbacks in North America.
I have a GFB Hybrid on my car because my friend had a lease returned Spec B and couldn't find his stock one. Fuel consumption didn't change so I'm guessing the AFRs aren't too different. |
#250 |
Member#: 206609
Vehicle:2002 WRX Black |
Hello guys,
I just recently bought my first turbo car. A 02 wrx. Since I was a teenager I love the sound of blow off valves. But couldn't afford a turbo car at the time. Well now I am 31 an after purchasing my house I came up with some cash to get me the wrx. My previous car was an impreza rs. Now my wrx is all stock except a greddy exhaust. I don't race just daily driving. My question is can I put a BOV with the stock motor without any issues. And which one do you guys recommend without breaking the bank. Thanks |
| Thread Tools | |
| Display Modes | |
| Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 321 | 06-13-2013 03:52 PM |
| Exhaust FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 260 | 05-16-2013 08:35 PM |
| Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 103 | 05-15-2013 01:15 AM |
| Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 283 | 03-15-2013 06:56 PM |
