Old 07-21-2006, 11:31 PM   #51
AsherBishop
Member#: 48231
Default HKS BOV Sound Issue???
I just got my first ever WRX today. I am trying to make sense of the previous owners mods. It has a HKS SSVQ BOV with a Recerc fitting but no tubing attached to it. Obviously it is not recircing, but does this make it quiter than without the recirc fitting attached? I was hoping to make it louder.
After reading about the Atmo BOVs causing lag due to fuel ratios I am thinking about recircing the air. But would that make less noise than venting to atmos, or in my current case... venting to atmos with a recirc fitting not attached to anything. Thanks for the help!!!
AsherBishop is offline   Reply With Quote
Old 07-21-2006, 11:59 PM   #52
BoostinEJ20
Member#: 73710
ok, the recirc fitting is a plus since you could rig it up to recirculate.
venting back to intake would make it pretty much silent as opposed to venting to atmo. that hks does leak before stock boost is reached iirc, so try to find a stock bpv if you can and sell that hks and make some money for other mods. what else does the car have for mods?
BoostinEJ20 is offline   Reply With Quote
Old 07-22-2006, 01:29 AM   #53
AsherBishop
Member#: 48231
Default Other Mods
The car also has a $2k StopTech Big Brake kit, Complete racing suspension by Cusco & H&R & KONI, Prodrive exhaust, A'PEXi Turbo Timer, and more I am forgeting.
I do have the stock wastegate, and call me a sucker, but I like the sound of the HKS BOV. If I want to just let it vent to Atmos could I change the way it meters the air fuel ratio? I heard someone say the HKS EIDS (Idle Stabilizer) adjust for atmos BOVs. Is that an option???
Thanks guys!!!
Old 07-22-2006, 05:25 PM   #54
kirkeemonster
Member#: 113721
WRBP
What about if I get say a BOSCH BPV that makes it a little bit louder than stock, just so I can hear it go pssssh but not loud as **** like all the ricers, would any BPV be better than stock? And would any BPV be better than a BOV
kirkeemonster is offline   Reply With Quote
Old 07-22-2006, 05:40 PM   #55
theicewall
Member#: 70532
2004 WRX
There is essentially no bov/bpv that's better than stock for stage 2.5 cobb and below, unless you bias your decision heavily on sound. If you want the sound, what I suggest is for you to purchase either a K&N typhoon intake and a recirculating Forge bpv or something of the sort. My buddy at turbometrics just got a few in and has a video clip or two where it sounds pretty good. Im not going to troll or talk up a vendor, so if you would like the link to those video clips just PM me. As long as you have a bpv that doesnt leak it is essentially the same as stock, but you've spent money on it for no performance gain. If the sound is worth it to you, buy an intake and recirculating bpv and it will sound about the same as a 50/50 valve. The best BOV is the Tial valve, but its 500$ and you cant run it without having the same problems of all the other atmospheric venting valves unless you have a hydra ecu with a manifold absolute pressure sensor instead of a mass air sensor. This measures pressure to calculate air volume instead of air velocity through a fixed circumference tube.
theicewall is offline   Reply With Quote
Old 07-22-2006, 05:42 PM   #56
theicewall
Member#: 70532
2004 WRX
Thanks guys!!!
Yes, Hydra EM with MAP sensor replacing MAF sensor = $$$$$$ & I believe its stand alone.
Old 07-29-2006, 04:14 PM   #57
alexk243
Member#: 103157
2005 WRX Wagon
I installed a friends ricer BOV just to see what it sounded like and how it affected performance and after about 10 mins of average driving the check engine light came on and the car had trouble idleing. It idled really rough. I think that probebly had something to do with it running to rich.
alexk243 is offline   Reply With Quote
Old 07-29-2006, 06:30 PM   #58
Babolat06
Member#: 118833
06 Impreza 2.5i
69 Cougar 351
I read your unabomber manifesto and i gotta say, you are doing something that is very appreciated and is helping a lot of people!
Babolat06 is offline   Reply With Quote
Old 08-04-2006, 06:06 AM   #59
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Correct me if I am wrong, but isnt a BOV also used to prevent a supercharger from trashing your block in accidendental extreme downshift situations, as a kind of one shot deal? Or is this a different kind of BOV.
atech_rallyrs is offline   Reply With Quote
Old 08-19-2006, 02:31 PM   #60
Jeremy Gill
Member#: 64373
2004 Impreza 2.5 TS
Red
I have a Forester XT. Is the BPV the same as the WRX's? If not, can I use the STI BPV? Will it even make a difference in sound? Mine's really quiet and I'd like to have a subtle sound to it.
Thanks
Jeremy Gill is offline   Reply With Quote
Old 08-19-2006, 05:21 PM   #61
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
A Subaru BPV is a Subaru BPV is a Subaru BPV.....they are all the same except for the JDM ones, which hold more PSI, but they ALL sound the same.
Old 09-01-2006, 01:01 PM   #62
Sc00byD00d
Member#: 83590
2004 WRX STi
Platinum Silver
Noob question... but a question none the less:
I have a TurboSmart Dual Port BOV on my stage 2 STi. Right now I have it set up venting to the atmosphere. If I switch it to vent to the intake will I eliminate/reduce some of the backfiring issues I am currently having?
Also the dual port allows for the gases to be vented to both the intake and the atmosphere simultaneously, has anyone tried this? What were your results?
- Scooby
Sc00byD00d is offline   Reply With Quote
Old 09-01-2006, 03:50 PM   #63
theicewall
Member#: 70532
2004 WRX
- Scooby
Yes, you will still run a little bit rich but it will solve your backfiring issues. You should do that immediately. I've tried it, and my results were about the same as stock but with a subtle wooshing sound and less of a tendency for rpms to climb for a split second after releasing throttle.
Old 09-03-2006, 01:33 PM   #64
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
i thought someone said a few posts up that recirc has no sound to it? i'm looking for a bit of sound without the loss of power, is that possible?
druxboyz is offline   Reply With Quote
Old 10-11-2006, 01:58 AM   #65
Dragicon
Member#: 112323
good post on the BOV's, i sure like reading info on this type of stuff.
Dragicon is offline   Reply With Quote
Old 10-13-2006, 08:20 PM   #66
kirkeemonster
Member#: 113721
WRBP
uhm then how come my stock bpv goes PSHH? lol, I just have to be on heavy load, I might get the forge recirc for the sound, but it will be a hell of a lot better than atmospheric, and I should still be able to here the pssh, just a lil louder.
Old 12-22-2006, 02:13 AM   #67
Kellan
Member#: 135556
okay well this thread has confused me more than it's helped me understand.
somebody route/explain the path of the stock BPV in comparison with an atmospheric BOV so I can mentally see the difference.
I've confused the hell out of myself to where the BPV doesn't even make sense now.
If it recirculates after the MAF sensor, it seems like it defeats the entire purpose of blowing off any excess boost since it's re-routed right back into the intake. ugh damn I'm confused.
if somebody could clear up the differences very meticulously for me, it would be much appreciated.
Kellan is online now   Reply With Quote
Old 12-22-2006, 10:33 AM   #68
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
I'm still a noob at this stuff too but from what I understand, a BPV sends air back into the intake track to keep the turbo spinning, this allows the car to keep power through the rpms during shifting.
A BOV sends excess pressure into the air and thus the turbo looses momentum which in turn causes the slight hic-up between shifts because it's like running and then kinda tripping?
In any, I'd like to get the Forge BPV but I'd like to hear what it sounds like so if someone could post a clip or something that would be helpful.
Knightmare69 is offline   Reply With Quote
Old 12-22-2006, 12:17 PM   #69
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Look at your OEM BPV. There is a large hose that goes from it back into your intake towards the left of your car. This is the recirculation path, excess pressure is relieved and goes back into the intake from the BPV through the hose. With an aftermarket unit, it replaces the OEM BPV and when it relieves pressure it does so through the BOV itself either through ports around the BOV or sometimes through a "horn" that is physically mounted to the BOV.
Old 12-23-2006, 04:57 PM   #70
Kellan
Member#: 135556
I understand that. What doesn't make a whole lot of sense to me is:
if the air you blow off get's immediately re-routed back into your intake tract, what was the point of even blowing any of the boost off? Unless of course the pressure on the way back to your intake is greatly reduced somehow.
It doesn't seem like that solves the problem, to me. If it's one big circle of air pressure, it seems like the recirculated blown-off boost is just going through some hoses and back into the intake at the same density/pressure it was "released". What am I missing here?
Old 12-23-2006, 05:13 PM   #71
modaddict
Member#: 95840
sold to a good bud
awaiting next car
The air gets blown off and routed PRE-turbo. Pre-turbo air is not compressed...POST-turbo air is.
You are taking compressed air....dumping it into a non compressed system. The goal is when the throttle plates close, there is a pressure wave that will travel back through the system and can cause a "surge". You vent that wave off.....back to the air intake.
modaddict is offline   Reply With Quote
Old 12-24-2006, 05:06 PM   #72
X-Factor
Member#: 101720
2006 Evo IX GSR/SSL
Electric Blue
bump...
X-Factor is offline   Reply With Quote
Old 12-27-2006, 08:31 PM   #73
+WRX+
Member#: 135960
Originally Posted by Unabomber View Post
Are there any negative effects with aftermarket BOVs? Yes. The downside of releasing the air to atmosphere is that it has already been metered by the mass air sensor, and when it blows off, the ECU will be injecting the wrong amount of fuel into the cylinders. The engine temporarily runs extremely rich, meaning too much fuel is injected into the cylinders.
Just to be sure....If I have the new 07' WRX sedan....Am I going to have trouble with BOV?....
+WRX+ is offline   Reply With Quote
Old 12-27-2006, 10:25 PM   #74
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Even if you have the 3035 WRX, it will still cause problems.
Old 12-27-2006, 11:34 PM   #75
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
WOW i wonder what it will look like. Anyway guys.......what is the reason everyone wants a blowoff valve. pssssssssssssssssssschaaaaaaaa. That's all it does. Sure it sounds cool for like the first 10 seconds and then it makes your car run like 1984 Geo Metro. Not good. So why does everyone feel the need to throw one on a stock car. WHY
JMK508 is offline   Reply With Quote
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 Yesterday 01:24 PM
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 326 11-20-2016 02:22 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 386 09-10-2016 07:42 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 11:03 PM
