Old 12-12-2003, 09:39 AM   #1
imprezive
Member#: 746
Default Spark plug gap with mods.
My 60,000k tune is due and I wanna really do a thurough (sp?) So I wanna get the best spark plugs and gap them correctly.
My current engine mods are; (I'm not even sure this matters)
Cobb CAI
Cobb "street performer" cams
Borla headers
Custom cat section
Blitz nur-spec axleback section
Lightened flywheel
I don't claim to be an expert, but it seems logical to me that with a lot more air flowing in the engine you might use a different gap then stock. Please correct me if I'm wrong. I always desire to learn more.
imprezive is offline   Reply With Quote
Old 12-12-2003, 10:15 AM   #2
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
I have a thread going like this as well...check it out.
http://forums.nasioc.com/forums/show...hreadid=467852
White2.5GT is offline   Reply With Quote
Old 12-12-2003, 10:42 AM   #3
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
As far as I learn on tuning engine, by checking spark plug on 2 stroke engine (every other run while competing), the gapping work this way. smaller gap is a warranty of a spark in harsh contition (rich, oily, humid) but it is less powerful. Larger gap may cause misfire in harsh condition, but if it make a spark, it will be more effective. sometimes it's usefull, sometimes is doesn't make a change. like everything else, bigger is not better. if you do not have a good spark at each explosion phase, you loose power.
In your case, i wouldn't touch to the gap. if your modification make the EGT goes up, but not because the air-fuel mix is lean, it could be useful and safer to go one step colder spark plug
NicEJ25 is offline   Reply With Quote
Old 12-12-2003, 12:10 PM   #4
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
honestly, i wouldnt bother messing with the gap on the spark plugs. but thats just me
ommmjido is offline   Reply With Quote
Old 12-15-2003, 12:25 AM   #5
Pengo
Member#: 41164
keep the gap stock, no need to mess with it. even with the few bolt on's you have, there isn't that much more air going into your engine. now if you went FI, there would be need for colder plugs and smaller gap. you should be fine just where you are. unless you're getting misfires, don't change it from stock.
Pengo is offline   Reply With Quote
Old 12-15-2003, 01:04 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
if you are reusing old plugs then you would want to check and adjust the gaps to get them into spec. But if you're going with new plugs then just check them and leave them(assuming oem replacement).
Good luck
Tim Sanderson is offline   Reply With Quote
Old 12-15-2003, 02:20 AM   #7
imprezive
Member#: 746
well I get misfires sometimes on cold starts. I've had that problem eversince I got my cams.........
I just wanna get the best. I was thinking about the denso iridium plugs. BUT at the same time I don't want to just throw my money away.
Old 12-17-2003, 10:29 AM   #8
imprezive
Member#: 746
bump
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 09:49 PM
Spark Plug Gap Scooby South Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-27-2001 12:10 AM
Spark Plug Gap??? Ben Legacy Forum 0 01-28-2001 10:49 AM
Turbo spark plug gap Tim Prudence Technical Forum Archive 9 09-14-2000 07:44 PM
Spark Plug Gap SubeDonC General Forum Archive 3 09-08-2000 06:06 PM
