Old 12-12-2003, 12:02 PM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default What if Coolant temp sensor didn't fix hard start?
I put in the engine coolant temp sensor, and my car does the same thing? It is really hard to start on mornings, always when it is cold. I will let it turn over up to 10 times and it mights stumble, but not start at all and then when I release the key it backfires. www.autoquoteresearch.com This happens maybe 2 times a morning, then I try it again, and it won't even click over. So then I usually wait 5-10 minutes and can usually get it after a few tries. Maybe it's the mileage.
I have a MY93 Impreza L 4EAT EJ18, w/ 206,000 miles
Any help woul be great!
Max
Max Umbarger is offline   Reply With Quote
Old 12-19-2003, 01:18 PM   #2
Max Umbarger
Member#: 1112
2006 FXT
RBP
bump
Old 12-19-2003, 01:35 PM   #3
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Time for a new battery? Is it turning over quickly and not firing? Or is it struggling to turn over at all?
If the latter, definitely time for a new battery.
heffergm is offline   Reply With Quote
Old 12-22-2003, 08:17 PM   #4
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
do you have a check engine light on?
if so what is the code
dave
PerformanceAutoSolutions is offline   Reply With Quote
CEL = engine coolant temp. sensor jrlegac8195 Service & Maintenance 1 10-30-2002 02:14 PM
Help finding Intake Air Temp or Coolant temp sensor jacksonww Legacy Forum 1 08-27-2002 01:42 PM
Stock coolant temp sensor Jewbaru Normally Aspirated with bolt-on Forced Induction Powertrain 7 07-17-2002 09:23 PM
Coolant temp sensor LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 11 03-19-2002 12:28 AM
