Old 12-12-2003, 02:49 PM   #1
terrapin
Member#: 39509
2002 wrx wagon 5spd
black
Default Tie Rods shot at 40k
I just had 215/45/17 Conti Extreme Contacts mounted on my Rota Tarmacs yesterday. The tech told me that both the tie rods were worn and needed replacement. I've noticed that the car wanders a bit on the highway especially is really windy conditions. I ordered whiteline steering bushings the solve the problem, but just wanted to see if anyone else has feedback on the tire rods. I plan on checking them myself tomorrow because I see it impossible for them to be shot on a car with perfect aligment and no front end damage.
terrapin is offline   Reply With Quote
Old 12-12-2003, 02:50 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i've never heard of these cars having bad tie rod ends, my car has 50k on it and they are still tight, did you jack up the front end and see for yourself?
Old 12-12-2003, 04:36 PM   #3
terrapin
Member#: 39509
2002 wrx wagon 5spd
black
I am looking tonight to check it out.
Old 12-13-2003, 04:24 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
the car could very well wander based on your alignment settings, i wouldn't point the finger directly at the tie rod ends just yet
Old 12-13-2003, 06:12 PM   #5
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
it happens, a way to check is to get the wheel off the ground and to grab the left and right side and see if there is any play side to side.
most of the time ive found it to be the inner tie rod wich could be costly.
YaZahX is offline   Reply With Quote
Inner tie rod shot switch900 Vancouver Impreza Club Forum -- VIC 3 01-24-2009 03:24 AM
MOOG Inner Tie Rods (Ball Joints and Outer Tie Rods also mentioned) Kostamojen Car Part Reviews 7 01-13-2007 01:49 PM
Broke Tie Rod getting pulled out of mud: OEM rod OK? powerlabs Service & Maintenance 2 04-15-2004 12:28 PM
is there any aftermarket inner tie rods and tie rod ends for subaru? Track Assassin Brakes, Steering & Suspension 2 01-28-2004 12:39 PM
inner tie rod diehardvw Brakes, Steering & Suspension 0 11-30-2000 12:52 AM
Message Board Statistics All times are GMT -4. The time now is 04:36 AM.
