Old 12-13-2003, 12:04 AM   #1
just_dave
Member#: 50466
1993 impreza
red
Default hard starting impreza
i have a 1993 subaru impreza manual transmission fuil injected the problem i have is the check engine light stays on and when it sits over night its realy hard to start then when it does start it runs ruff for few min then runs fine rest day recently i descoverd if i take the battery wire of over night when i put it back on the light goes out and the car starts right up but after a few miles the light comes back on i have to take the battery wire of every night any suggestions????? bad computer maybe??
just_dave is offline   Reply With Quote
Old 12-13-2003, 11:40 AM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
Taking the cable off resets your computer, so the light goes away for a while. Sounds like you may either have a bad battery or an electrical drain causing the hard starting.
orndog is offline   Reply With Quote
Old 12-13-2003, 11:43 PM   #3
just_dave
Member#: 50466
1993 impreza
red
i put a new battery in it new battery terminals still does the same lately even when the light is out its gettin so that it floods out when i go to start it after its bein drivin for awhile i have to hold the throttle wide open and turn it over for a long time it could have a short sometimes it makes a clicking sound when the check engine light comes on or goes out and the light dim as it clicks i realy hate to take it a garage and put more money into it i plan to trade it in for a outback this summer if i can keep it runnin that long so any suggestions would be helpfull ///also when you let it idle the check engine light clicks on and off constant sometimes it will idle 3000 rps u have to shut it off and start it back up to get it idling right thanks dave
Old 12-21-2003, 07:41 PM   #4
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Have you checked the alternator, starter, plugs and fuses? Also, check your service manual.
joubtt is offline   Reply With Quote
Old 12-22-2003, 12:49 AM   #5
Borgus
Member#: 49375
Definitly sounds like one of these to me. Also, check your distributer cap. Spark plugs have been known to do this as well...
Borgus is offline   Reply With Quote
Old 12-22-2003, 03:25 PM   #6
just_dave
Member#: 50466
1993 impreza
red
it has new plugs and wires i just had a tune up done about a month ago it may be a starter or alt but the starter dont drag and it seems to charge good just starts hard in mornins if the check engine light is on. if the lights of when i shut down the car at night it will start right up the next day. if not i gotta take battery wire of for about 30 min then it will start i cant find my service manual its bein a tuff car got almost 2 hundred thousand on it dont burn oil still goes like a new car when it starts iv deff got my moneys worth from it thanks for your suggestions ill look into it and hopefully it is one of those that are bad
Old 12-28-2003, 11:06 PM   #7
kevinsUBARU
Member#: 2263
2012 Impreza Sport
There is not a distributor cap since we have coil packs. Could be cam/crank sensor or the coil pack. Mine did the same thing, and would go away when the battery was unpluged to reset the computer, but then come back.
kevinsUBARU is offline   Reply With Quote
Hard starting 2002 Impreza Puffie40 Normally Aspirated Powertrain 8 11-18-2008 09:04 PM
95 impreza 1.8L--randomly hard starting, stalls occassionally scoobysteve95 Normally Aspirated Powertrain 5 01-09-2005 11:07 PM
cel ,dtc codes -p0115,p0505, and occasional hard starting impreza subaru6 Engine Management & Tuning 1 03-11-2004 12:16 AM
