Old 12-13-2003, 08:36 PM   #1
Unsung Boxer
Member#: 37196
Default Fuel/Ignition Cut, Emanage Logs Here
For those of you who dont know the symptoms:
Earlier Thread of Symptoms
As promised, my Emanage Fuel/Timing Map:
Jake.GSC
And here, is the Emanage Datalog of Fuel/Ig Cut Problem:
Cut.LGD
Cut.LGI
Note:
This was at 10psi, EGT's never exceeded 1500F
Stock Revlimiter =6200RPM
In this Datalog, the 3 RPM Peaks represet 1,2, and 3 Gear consecutively. I am NOT experiencing this in 1st gear, I just shifted 200rpm before Redline. The 2nd and 3rd Peak, were induced by the ECU.
Analyze away
-Jake
Unsung Boxer is offline   Reply With Quote
Old 12-13-2003, 08:46 PM   #2
Unsung Boxer
Member#: 37196
BTW, you have to have the Emanage Support tool to view these files. You dont have to have the Main Unit
http://autos.groups.yahoo.com/group/emanage/message/212
http://autos.groups.yahoo.com/group/emanage/message/220
-Jake
Old 12-13-2003, 09:13 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Jake, you have to post the .LGI and the .LGD file for people to be able to see the log. It also might be easier to post the excel version for those that don't have the support tool software installed. (Look in the files section of the yahoo group for the excel converter if you don't already have it)
lotusTT is offline   Reply With Quote
Old 12-13-2003, 09:34 PM   #4
Unsung Boxer
Member#: 37196
Ok, edited first post to include .LGI file, but it wont be until my friend uploads it that you can download it... hopefully it will happen within minutes from this post.
Got a link to download the convertor? I can't find it.
-Jake
Old 12-13-2003, 10:03 PM   #5
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I don't think I can directly link to it. Its called "EmanageDataConvert.xls " its the 6th item from the top.
Old 12-13-2003, 11:26 PM   #6
Unsung Boxer
Member#: 37196
I dont have excel on my computer, that is an excel filetype.
At this point, can you tell me anything about just my fuel map?
-Jake
Old 12-14-2003, 12:37 AM   #7
Unsung Boxer
Member#: 37196
Figured out another way to do this:
Here is a pic of the RPM spikes
Old 12-14-2003, 12:42 AM   #8
Unsung Boxer
Member#: 37196
Red is RPM
Green is TPS signal
Old 12-14-2003, 12:50 AM   #9
Unsung Boxer
Member#: 37196
Fuel Map
Old 12-14-2003, 12:52 AM   #10
Unsung Boxer
Member#: 37196
Timing map... i think im way off on this one.
Old 12-14-2003, 12:55 AM   #11
Unsung Boxer
Member#: 37196
Boost Cut Limiter Map
Old 12-14-2003, 12:59 AM   #12
Unsung Boxer
Member#: 37196
Main Unit Settings, note the Parameter setting i have selected.
Old 12-15-2003, 12:28 AM   #13
Unsung Boxer
Member#: 37196
ok, after examining my own maps, i realized they are considerably different than what i rmemebered tuning last.
Since i posted these maps, i made the retard come in sooner, as well as the richer fuel.
Seemed to solve the problem... but well see.
-Jake
Old 12-15-2003, 10:05 AM   #14
Kha0S
Member#: 8808
2011 WRX
DGM 5D
What are your symptoms? If you're misfiring, you might want to re-jumper your eManage internally to use 12V ignition output instead of 5V... although, I have no idea if that is necessary on the RS ECU (it is for the coil-on-plug WRX ECU).
/Andrew
Kha0S is offline   Reply With Quote
Old 12-15-2003, 10:12 AM   #15
OKRS25
Member#: 36533
2005 STi
Tried to download the log file and I couldn't see it. I would like to see a log file that shows total injector duty cycle and duration, a/f adjustment percent, and timing adjustment
OKRS25 is offline   Reply With Quote
Old 12-15-2003, 10:22 AM   #16
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Yeah, get the .LGI file up there and we'll be able to provide more help.
Old 12-16-2003, 05:26 AM   #17
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
sorry if this is off topic but can you tell me what the numbers in the first collum represent on the fuel map?
Nate
NateDogg is offline   Reply With Quote
Old 12-16-2003, 07:07 AM   #18
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
throttle position
Launch Control - Fuel vs. Ignition Cut. Teh Legacy UTEC 29 09-04-2013 07:16 AM
Meth + Launch control... Fuel or ignition cut?? rpeirats Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-05-2009 11:05 AM
Factory rev limiter, ignition cut or fuel cut? rice h8r Off-Topic 19 04-29-2008 10:04 PM
Knock due to Ignition Cut? Logs inside. Teh Legacy UTEC 9 12-08-2007 11:10 AM
Fuel Cut or Ignition cut on an STi wolfemancs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-06-2005 06:24 PM
