Old 12-14-2003, 08:49 AM   #1
wRxbeater11
Member#: 12682
Default Ej257 block w/ ported WRX heads?
Since my cly 4 is still dead I was planing on buying a STI block In a week or so and throwing her in my Suby. Anyway I've herd that with WRX heads they dont flow right, is this true? will it decrease power that much? I realy dont want to run into any problems while doing this install so if theres anything I should know about please inform me. How much Hp and torque would this setup give me? (estimated numbers) One more thing, a few months back i had my WRX heads ported at a machine shop so maybe this would help some?
-Melo
wRxbeater11 is offline   Reply With Quote
Old 12-14-2003, 01:31 PM   #2
mlambert
Member#: 13831
Its not that they wont work, youre just leaving alot of power on the table with the wrx cams. The fact that they are ported should help a fair amount.
HP depends on what turbo youre going to run. I wouldnt go with anything smaller than a VF22/old pe1820 size. You'll have more than enough torque to make a 5MT puke.
mlambert is offline   Reply With Quote
Old 12-14-2003, 01:52 PM   #3
DanMan
Member#: 5009
Porting would be nice, but you'd be better served with a set of cams.
The USDM STI ones are $150 each (x4) and available at your dealer. They should
keep the motor from falling off at 5000rpm.
You've got to pull the cams out to change the heads anyway... so there is no extra labor involved. Money better spent IMO.
Dan
DanMan is offline   Reply With Quote
Old 12-14-2003, 03:11 PM   #4
wRxbeater11
Member#: 12682
$150 a cam? thats not to bad at all. Thanks alot guys for all your help =]
Old 12-14-2003, 03:39 PM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
More to it then just the STI cams guys.
Just wait on that comment.. right now Ron over at Axis is measuring up what it takes to run them. It's not a "drop in" deal with those cams. You need valvetrain hardware for sure.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 12-14-2003, 04:11 PM   #6
DanMan
Member#: 5009
Jorge (RiftsWRX)
www.ProjectWRX.com
Any more specifics? Are we talking about something like a bucket conversion or a large fitment issue?
Thanks,
Dan
Old 12-14-2003, 04:34 PM   #7
jarelee
Member#: 31506
05 Tacoma on TE37'
OT: Is it useful to use STI cams on a 2.0 WRX motor? Would it help and keep the powerband past the WRX cam redline??
jarelee is offline   Reply With Quote
Old 12-14-2003, 08:59 PM   #8
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
what about AVCS?
stickman is offline   Reply With Quote
Old 12-14-2003, 09:57 PM   #9
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
To use the AVCS you would need an STi ecu.
Unless new info has come to light since sponaugle posted his cam thread the USDM STi cams are not a whole lot bigger the USDM WRX cams if at all, they are practically the same size just slightly higher lift.
There is another guy who put in a EJ257 with poted heads and he seemed to be pretty happy.
roybfr is offline   Reply With Quote
Noob builder - Questions: EJ257 block with '06 WRX heads? saab-on-the-cobb Built Motor Discussion 2 03-13-2009 09:51 PM
EJ257 block with ported WRX heads and bigger cams wrxfactor Subaru Conversions 6 05-09-2006 10:27 AM
Ported WRX heads and bigger cams on 2.5L block wrxfactor Factory 2.5L Turbo Powertrain 8 05-04-2006 05:35 PM
EJ257 longblock, ported WRX heads and larger cams wrxfactor Built Motor Discussion 8 05-04-2006 09:29 AM
FS New EJ257 USDM STi block, gaskets, upgraded WRX heads and more roybfr Private 'For Sale' Classifieds 19 02-23-2004 12:51 AM
Message Board Statistics All times are GMT -4. The time now is 06:10 PM.
