Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 12-14-2003, 06:57 PM   #1
curnuck
Member#: 50546
Question subaru to vw conversion
I am considering a EJ20 turbo swap into a beetle. I know that it has been done but what I want to know is, can i somehow still use a subaru transaxle? I was wondering if anyone knew if i could switch the ring gear as can be done with early vw transaxles when they are mid mounted. I have also seen a 2wd legacy transaxle with a ej20 midmounted in a bettle floorpanned kit car, but I don't think this would work within the confines of a steel body beetle. I have also heard of but have not seen subaru transaxles run upside down in rail buggies??? but can't see how.
any info would be greatlty appreciated
curnuck is offline   Reply With Quote
Old 12-14-2003, 10:40 PM   #2
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
i remember someone doing a WRX-VW swap in the VWvortex.com forums.
StarDogChampion is offline   Reply With Quote
Old 12-15-2003, 12:25 AM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
do a search I know its been covered before some guy using a FWD subie trans axle for a vw or porche I don't know try searching things like "trans axle" or "VW" under converison forms you'll find a lot
scobaru is offline   Reply With Quote
Old 12-15-2003, 12:29 AM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
forgo about the 3 word search minium I'm sure you'll find something
Old 12-15-2003, 02:01 AM   #5
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
hey- usually the word on thos things is use VW/porsche trans with kennedy engineering bellhousing. dunno who this kennedy guy is,but he must be getting mad business. or is a great hype machine.
h
supermoose is offline   Reply With Quote
Old 12-15-2003, 09:23 AM   #6
elwood91
Member#: 36133
2003 wrx silver
05 2.5 i wagon/87 Syncro
try smallcar.com their specialty is subaru engines into vanagons
elwood91 is offline   Reply With Quote
Old 12-15-2003, 09:51 AM   #7
Calimoxo2
Member#: 34531
'84 1/10 BRAT
Red
I was looking through a Dune Buggy magazine this summer and half the magazine was a write up on all Subaru engines through the years and how they can be used instead of the VW boxer in RWD buggies..... Oh to live in AZ or NM.....
Calimoxo2 is offline   Reply With Quote
Old 12-15-2003, 04:48 PM   #8
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
I dunno about a Beetle, but I remember someone talking about swapping an EJ20 into a 914 a while back. It may not provide you with what you're looking for but may give some leads. You might wanna try searching for that. *shrug*
bigdweeb is offline   Reply With Quote
Old 12-15-2003, 06:09 PM   #9
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
here ya go somthing like this
check out the sand rail guys..
Old 12-15-2003, 07:42 PM   #10
curnuck
Member#: 50546
I have used kennedy adapter plates and others before. For a 13b rotary rail buggy, pinto rail and a 74 VW bus with a EA82 subaru. These kennedy adapters are EXELLENT quality and do an exellent job , to a point.
The reason I want to go with a subaru transaxle is to get 5 gears, better ratios, relaibilty,and streangth (ie. wrx gearboxes are made to handle turbo jap power). I understand all these things CAN be built into a VW based box but that requires serious cash.
Any direct link or contact would be greatly appreciatted as as my searches are comming up nil.
Old 12-15-2003, 11:07 PM   #11
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
This is the thread I was thinking about:
http://forums.nasioc.com/forums/show...628&perpage=25.
You can read that through and see if there's anything helpful in it for you... I think he may be using a 914 tranny with a Subaru motor though. You could maybe pick his brain to see if he has any ideas for you too. Good luck!
Old 01-28-2004, 01:35 PM   #12
Gnuen
Member#: 53761
Hey Guys i just stumpeled on this thread and wanted to pass on a link i stumpeled on the other day, sadly this is also a porche 914 page, but it has lots of pictures from a conversion from a 914 air cooled engine to a 1,8 Subaru water cooled one. just press here btw. nice Midget that guys has made... or is it just me.
ps. sorry for my bad spelling and/or grama, Ėnglish is not my native language.
Gnuen is offline   Reply With Quote
Old 02-16-2004, 09:04 PM   #13
serious
Member#: 22879
"wrx gearboxes are made to handle turbo jap power"
Booooohahaaahaaa....that's the funniest thing i've read all day....thanks for the laugh.
Brent
serious is offline   Reply With Quote
Old 02-16-2004, 09:20 PM   #14
steve_d
Member#: 315
yeah, and my 1967 porsche 4 speed can handle small block chevy power...REALLY....it was designed that way.
it'll actually have to handle EJ18 power.
sjd
steve_d is offline   Reply With Quote
Old 02-17-2004, 12:25 PM   #15
MadRobbo
Member#: 54636
I've got an Ej22 in the back of my Sand Rail, and I build the transmissions for a few of the guys who drag race Subaru engined beetles.
Its a simple enough conversion, Kennedy make adaptor plates and if you use one of their clutches you'll be fine in that area.
As for transmission strength, the VW that did a 12.1 1/4 had the sum total of 2 high performance parts - both of them Bugpack woodruff keys. We welded the diff solid (dangerous), and tig welded the 3rd and 4th gears.
You can handle plenty of power through the VW transaxle, you just need to buy the right bits: Superdiff, HD cover plate, tig welded 3rd and 4th gears.
Take a look here:
http://www.tsrdragracers.co.uk/index2.html
Rob
http://www.phattransmissions.com
MadRobbo is offline   Reply With Quote
Old 02-18-2004, 07:57 PM   #16
steve_d
Member#: 315
cool rob.
do you know if the kennedy adapter is the same for all ej blocks???
I'm starting with 1.8 power now in the porsche, but will be thinking about 2.5L power in the future.
sjd
subaru to vw bug engine swap? jay_cat Newbies & FAQs 5 04-02-2008 03:45 PM
WRX trans to FWD for a VW conversion FestaH Subaru Conversions 3 12-05-2007 09:50 PM
WRX/VW conversion.... vanaru Factory 2.0L Turbo Powertrain 7 06-01-2006 04:56 PM
Kudos to VW ads-I would like Subaru to put this ad on TV NextCar General Community 12 04-25-2006 08:25 PM
subaru to VW curnuck Subaru Conversions 4 12-23-2003 05:28 PM
