Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 12-15-2003, 10:02 PM   #1
wgknestrick
Member#: 32576
04 STI
Default My FMIC pics 56K beware
I know pics suck because my car has been salted and this is in my weathered garage. I'll post again once I have a chance to clean it.
Sooooo much work between porting the VF39 and installing FMIC. IC water spray also works too All I need now is my mbc / boost gauge to get here so I get the 1psi I lost to the FMIC and the 1.5psi I need.
wgknestrick is offline   Reply With Quote
Old 12-15-2003, 10:12 PM   #2
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
that's one biiiiig fmic . very nice. modding an sti to that extent = balls. when the hell are they gonna bring out the engine management?
MikeWRX-NJ is offline   Reply With Quote
Old 12-15-2003, 10:29 PM   #3
wgknestrick
Member#: 32576
04 STI
Not soon enough. I hope to break 11s by the end of 2004 and not anything else. All I have left to buy (hopefully) is Forced Performance Green turbo (aiming high for now), injectors (when they come out), Utec (when it comes out), WI kit, and Walburo fuel pump.
Old 12-15-2003, 10:42 PM   #4
InfamousDX
Member#: 25413
How did you paint your IC??? When you posted those pics it was still silver right?? As I hear, unless it's anondized a color, it degrades performance... just wondering.
Oh and it's Walbro
Old 12-15-2003, 10:56 PM   #5
wgknestrick
Member#: 32576
04 STI
I just painted it with flat black high temp. Only 2 very thin coats on the front. Pics show a spot I need to touch up too. I can't imagine how much effect the paint is going to do because almost all of the cooling occurs inside the IC and that has no paint on it. You can't even feel a conduction difference between the painted an unpainted sides.
Old 12-15-2003, 10:58 PM   #6
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
STEALTH = HHOTTTTTTTTTTTTTTTTTTTTTT!!!
Pinochle is offline   Reply With Quote
Old 12-16-2003, 02:24 AM   #7
InfamousDX
Member#: 25413
Yea I figure if anything, it would make a neglible difference anyway. I had a stealth black IC on my old civic.. they are PIMP.
Old 12-16-2003, 03:06 AM   #8
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Now that is SWEET!!!!!!!!
Also, love your headlights
WRX_02_227 is offline   Reply With Quote
Old 12-16-2003, 07:27 AM   #9
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
whys the BOV on the wrong side??
YaZahX is offline   Reply With Quote
Old 12-16-2003, 07:53 AM   #10
wgknestrick
Member#: 32576
04 STI
Compared to what? It is in the exact same place as it is with the stock TMIC
Old 12-16-2003, 08:19 AM   #11
subimatt
Member#: 43680
BMW 335xi,x3,e30
are you going to replace the hood as well?
subimatt is offline   Reply With Quote
Old 12-16-2003, 08:44 AM   #12
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Nice setup!
He means where it's connected to the IC piping. I always found it strange that Perrin mounted the BOV right after the turbo instead of right before the throttle body. It's the only setup I've seen like that for any turbo'd car.
-Anthony
atf78 is offline   Reply With Quote
Old 12-16-2003, 12:57 PM   #13
wgknestrick
Member#: 32576
04 STI
I'm not sure. It will still vent the pressure whether in front of the IC or behind it. It might be why the car is runing slightly rougher or it could just be that any FMIC makes the car run slightly rougher without EM. My car is getting to be well modified over stock and the ECU does some crazy things sometime. I think I am leaving at least 40HP on the table without a tune. Thank god boost creep is gone now though because I almost forgot how far down the pedal would go. Fuel cut is very violent and scary when it happens, almost like a blown engine.
Old 12-16-2003, 02:27 PM   #14
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
Originally posted by atf78
Nice setup!
-Anthony
i think they did it so teh stock bov and piping would bolt right up... but i always though the BOV should be next to the TB... perrin makes really good stuff, i just dont understand why they did it...
Old 12-16-2003, 02:51 PM   #15
2sour4u
Member#: 13733
05' Saabaru
Black YO!
Bill is the man! Your car is starting to really look amazing. I love the stealthy black look. I think I would have sone the same thing. Heres a silly noob question for you. What is that red soda can looking thingy in the bottom right of the pics in front of the battery? Is that your balast for the HID's? Just curious. Anywho, PM me or give a call whenever your not busy. We need to double date again.
Jon
2sour4u is offline   Reply With Quote
Old 12-16-2003, 02:53 PM   #16
InfamousDX
Member#: 25413
^^ Oil catch can?
Old 12-16-2003, 03:14 PM   #17
wgknestrick
Member#: 32576
04 STI
That is just the coolant overflow tank. The piping runs right where the stock one is and they provide you with that "trick" canister. It is hard to see the level of the coolant though and it is just Samco hose with billet Al endcaps, but at least it looks nice. My car is either leaking coolant now or I have another problem, but I have had to fill that tank 2 times already. Car isn't running hot though and I bled all the air out of the coolant system.
[Bugeye n M3] Few pics with my new XTi [56k beware] kirkeemonster Member's Car Gallery 15 11-23-2007 08:15 AM
My Mt. Hood Pics!!! 56K BEWARE!!! stiguy21 North West Impreza Club Forum -- NWIC 13 08-14-2007 04:02 PM
Pics of my MBP wrx *56k beware* dirtyhartland Member's Car Gallery 20 03-02-2005 12:31 AM
BORED pics of my 05 sti - 56k beware big pics wrxtremeWGN Member's Car Gallery 8 02-12-2005 07:12 PM
