Old 12-16-2003, 02:58 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default hot start issue.
ive got a poo-ey hot-start issue on my swap (complete EJ18 brains running DOHC EJ25). the issue has just come up recently, it has run about 10,000 miles perfectly happy with out problems.
symptons: when stuff is warm after car has been running a while, and i park it for a short period - 5-10 minutes mostly, less than 1/2 hour ive observed, the car when fired up again, will crank and then die.
after i get some rev's on it it will go, and afte rsome load on the motor it will idle hapyily.
what ive changed to other parts that were not known as defective:
coil pack
spark plugs (2x)
crank pos. sensor
cam pos. sensor
engine coolant temp sensor
GDA fuel pump conversion (tonite)
** just swapped charcol canisters and 1 way valve thingy tonite*** we will see tomoro.
the issue has been on and off. sometimes more annoying than others.
so suggestions are welcome.
supermoose is offline   Reply With Quote
Old 12-16-2003, 12:00 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not sure that these are good ideas but some ideas
pcv
check for a vacume leaks
fuel filter
Old 12-16-2003, 12:32 PM   #3
supermoose
Member#: 9093
swap starr
oh-
PCV was replaced last week, fuel filter is 13,000 miles new
i suppose i could swap it with one ive got sitting from a JDM clip, but htats got 60K on it...
no vacume leaks i kno of.
h
(Halp!) Engine cutout & dies intermittently along with hot start issue DinoGuan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-30-2010 06:30 PM
Hot start fuel issue, trimming fuel @ idle... EntertheWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-16-2009 07:39 PM
Hot start issue Desibabu345 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-03-2008 07:25 PM
96 Legacy 2.2 hot start issues b1pig Normally Aspirated Powertrain 0 06-28-2006 08:41 PM
hot start issue with ignition supermoose Service & Maintenance 7 12-16-2003 02:11 AM
