Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-16-2003, 09:38 AM   #1
jgaffney
Member#: 41061
2003 Baja
Yellow
Default Bed Extender Lock System ?
How do you prevent someone from stealing your bed ext.? ive seen them with big cables and a pad lock ,there's gotta be a better way!
jgaffney is offline   Reply With Quote
Old 12-16-2003, 05:26 PM   #2
SouthShoreBaja
Member#: 50658
2006 2.5RS
I haven't bothered with trying to secure mine. I see another Baja on the road maybe once a month at most. That will change only slightly, given the lack of advertising Subaru has done to market the new BajaT.
SouthShoreBaja is offline   Reply With Quote
Old 12-17-2003, 10:25 AM   #3
Peloquin
Member#: 41307
2003 Baja
Regatta Red/Silver Stone
So long as you keep the tail gate up, they can't get the bed extender out without lowering the gate. If you have the alarm system, lowering the gate sets off the alarm. I haven't tested it, but I think it's the pulling of the handle on the gate that trips the alarm so if you lock the straps on the bed extender to the gate like you're supposed to, unless they cut the straps, they'd have to pull the handle to get the extender off still, which would trip the alarm.
That's all I know of to keep someone from stealing your gate (short of cables and a pad lock, as you mentioned).
Peloquin is offline   Reply With Quote
Old 12-17-2003, 01:54 PM   #4
Peloquin
Member#: 41307
2003 Baja
I played with my tailgate at lunch. It turns out that the handle does not trip the alarm. So that would not be an effective method of "Securing" your bed extender.
Old 12-17-2003, 02:33 PM   #5
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default Baja needs a locking tailgate...
like that found on the Ford F-150 and others.
Bob
rsholland is offline   Reply With Quote
Old 12-18-2003, 12:11 AM   #6
BajaNut
Member#: 36905
2014 Outback SAP
leggtnut on lgt.com
I was under the impresssion that the bed extender is the exact same one as the one on the nissan, ford, mazda, etc... At least that is what a (an sleazy salesman at a sleazy dealership) told me, but I guess that I should take it with a grain of salt. I haven't asked a repitable dealier and salesperson yet.
Ben
BajaNut is offline   Reply With Quote
Old 12-18-2003, 09:29 AM   #7
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Ben
They look the same, but probably each one is a slightly different size to fit each model.
Bob
Old 12-28-2003, 02:25 AM   #8
Postalshark
Member#: 41949
2003 Baja
they are the same. That is why I don't leave mine in my Baja.
It is adjustable for width and is held on with just 4 bolts.
I wish they were a Baja only part. I am looking for a way to secue mine also.
Postalshark is offline   Reply With Quote
Old 12-28-2003, 07:30 AM   #9
hatake
Member#: 34811
04 Baja T
I have security upgrade, and it did trip the alarm when I lowered the gate without unlocking the car. Flimsy beep, beep, but it was an alarm system kicking in. Now, when I look at the options list, security system for tubo is different - so maybe they changed the configuration with turbo model? This alarm won't "prevent" the crocks from stealing it, but it'll beep if one tries to do so - if someone hops on the bed, then snatches the extender and run with it, then it won't do much...
hatake is offline   Reply With Quote
Old 01-13-2004, 11:22 PM   #10
Baja Turbo
Member#: 49744
2004 Baja Turbo 10
Regetta Red Pearl
Default Bed Extender lock
Heres one way you can do it.I took some flat peices of metal about a inch wide and thick as nickel.Tappered one end so it would just fit in the slot where the extender goes,drilled a hole in the other end and then painted and installed them.Use the upper mounting bolt to the bracket to install the locks.Now with the metal plates blocking the holes the extender can't be lifted up. Its cheap and easy to do and not that noticeable.
Baja Turbo is offline   Reply With Quote
Old 01-14-2004, 09:12 AM   #11
hatake
Member#: 34811
04 Baja T
Noble idea! You should patent it - seriously. Or suggest SOA (giving up rights, but may help them come up as an option). Thanks for the idea!
Bed Extender gstien Baja Forum 0 11-16-2006 05:23 PM
Quick - should I get the bed extender??? What other options??? paddleboy Baja Forum 22 08-28-2006 02:58 PM
Bed Extender for Subaru Baja Loscocco Baja Forum 6 02-16-2006 04:03 PM
Bed Extender for Subaru Baja for sale cheap SF BAY AREA Loscocco Private 'For Sale' Classifieds 0 02-10-2006 02:27 AM
bed extender johnhandy Baja Forum 11 07-04-2004 12:37 AM
