Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 01-09-2001, 10:50 AM   #1
ConeMasher
Member#: 2135
Post WRX 17 inch rims... Autocrossing
Do you folks think that the WRX 17 inch rims will be an option or simply a dealer-installed add-on. The reason I ask is for SCCA Solo II Stock class autocross purposes....
I'd definitely rather run a 17x7 rim than a 16x6.5!
Also, I'd like to hear some conjecture as to the widest wheels we can shoehorn on the WRX. I believe the RS could run 245/45R16 (with slight rubbing) on the front and 225/50R16 on the rear.
I would LOVE to hear that the WRX might be able to run my 245/45R17 Kumho's all around.
Tire: 245/45/17
% Speedo Error: 3.228
Top Speed 1st: 39.7
Top Speed 2nd: 70.43
Tire: 245/45/16
% Error: 0.791
1st: 38.16
2nd: 67.69
STOCK:
205/55/16
% error: 0
1st: 38.46
2nd: 68.23
So the gearing favors the 245/45/16 in terms of quickness, but the 245/45/17 will yield more overall grip due to the extra 1/2 inch of rim supporting the tire...Bradley Lamont ran 245/45/16 Kumho's on his stock class GSX (16x6.5) and he seemed to get some sidewall roll.
My other concern with 245s (both 16 and 17 inch) would be heating the tires... the WRX is ALOT lighter than my previous steed (GSX also), and although I didn't have problems heating the tire with my 16x8 245/45/16 street prepared rim/tire combo, the WRX is at least 200 pounds lighter. There might not be enough time to get the tires up to optimal temp. In this case, 225s might be the best option.
Lets think about this!
-- ConeMasher
ConeMasher is offline
Old 01-09-2001, 11:06 AM   #2
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Lightbulb
I think the 17" rims are going be considered a dealer installed option. So stock will have to run the 6.5" rim.
Why not run the 225/50-16 Kumho. What will your speeds be in each gear for that tire?
I'm going to go straight into SM, so I'm wondering if a 15" rim will fit over the brakes.
I'll be at a disadvantage anyway though(for auto-x), since I'm getting the wagon.
Travis R is offline
Old 01-09-2001, 11:07 AM   #3
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
So uhh.. dumb question, what is the difference between an "option" and a "dealer installed deelio"?
If you mean that the "option" is a factory item, supplied at all SOA dealers versus just some sales manager's decision to put chrome 3-piece wheels on the car and mark em up, then yes, the 17" BBS wheels are an option. I bet they would be somewhere in the $1K range, not cost effective IMHO for wheels of questionable quality and probably RE92 rubben too. But will SCCA stock classes let you run another aftermarket wheel of the same size? Then great! 215/45R17 is the stock size in the rest of the world so we know it will fit.
It may be all a moot point, anyway, if SCCA sticks us into AS or maybe even BS. Sure we may have 230hp and AWD, but we also weigh 3100lbs. Not competitive with the RX7s of the world.
Necromancer is offline
Old 01-09-2001, 11:15 AM   #4
KC
Member#: 442
16 SS
00 S2000
Post
RX-7 is in SS, right? Against the Vettes.
I would think the 17" rims would be shod with 215/45-17 rubber, not 245.
Have you seen the cost of tires are available in a 215/45-17?
According to tire rack, they are generally a bit more expensive (From about $50 to $200 per 4 tires) than the 205/55 counterpart.
And there's no competition rubber in a 215/45-17 size.
--KC
[This message has been edited by KC (edited January 09, 2001).]
KC is offline
Old 01-09-2001, 11:23 AM   #5
ConeMasher
Member#: 2135
Post
Why would you be buying 215/45-17 inch rubber for your 17s??? I'd be tossing those RE92s faster than you can blink, and forgetting anything that tiny. You see, KC, you can run whatever tire size you can shoehorn on your stock rim. Who cares if there's no competition rubber in 215/45/17... throw the 225s or 245s on there (if they fit!).
Necromancer...
Yep, any rim with with stock width and offset +/- 1/4". So if the 17 is considered an option from the factory (and not the dealer), then we've got the charter to find the lightest 17x7 rim on the market
-- ConeMasher
Old 01-09-2001, 11:29 AM   #6
Jewbaru
Member#: 1994
2013 Impreza WRX
Post
uhh... their BBS wheels aren't they? Questionable quality?
Jewbaru is offline
Old 01-09-2001, 12:06 PM   #7
Gary (gg)
Member#: 179
98 2.5RS
Rally Blue
Post
I ran the 245/45R16 and 225/50R16 combo. The advantage of running autox R compound tires is that they heat up quickly. By the end of my first run they were up to temp. Here is what I would do if I intend to autox the WRX, assuming with the limited aftermarket parts the first year that most buyers will run stock class:
If the car comes with 205/55R16's on 7"x16" rims, I would run 225/50R16's and pay close attention for clearance. If there is no rubbing anywhere, then move to 245/45R16's.
If the WRX comes with 7-7.5" x 17" as an option with 215/45R17's, 225/45R17's all the way around and then switch to 245/40R17's if no rubbing with 225's. I don't think Kuhmo makes a V700 in that size though.
Personally, I would run 16" over 17" because:
1. 16" RS rims are available as a second set, (cheap)
2. Weight for 16" and 17" tires/rims differ by about 1-2 lbs per corner in favor of 16"
3. The 16" autox tires are cheaper.
4. The autox tires have very stiff sidewalls, to get better handling from the tires will be a matter of finding the right tire pressure. The lower aspect ratio will not help a tire handle better.
Don't forget the alignment.
The WRX may qualify to run stock class at Nationals this year because I believe it is being released early enough and 1,000 will be available in the first 12 months since its release if not by Nationals.
Gary (gg) is offline
HTML code is On
WTB- Stock 06-07 WRX 17 inch rims rocketwrx NESIC Private Classifieds 0 12-10-2007 09:57 PM
Will 06 wrx 17 inch rims fit 02-05 wrx? skycruise Tire & Wheel 2 09-21-2005 07:38 PM
WTT: 17 inch Prodrive p1 in anthracite for dark color 17 inch rim! Erexxx Private 'For Sale' Classifieds 29 09-08-2005 02:47 PM
Possible Trade: UK WRX 17 inch rims Maximum Tri-State Area Forum 26 12-23-2001 04:19 AM
