Old 12-16-2003, 07:43 PM   #1
GinoEJ253two
Member#: 50464
1999 Impreza 2.5 RS
Default Power Steering Lines always in the way
They Are always in the way..
I tried bending them with a pipe bender.. that didn't work out very well
anyone know a good way to bend these without teaking them..
what kind of place would do pipet work like that??
I was thinking of making my own that go off to the side.. but the fittings on the power steering are odd balls (the ones at the bottem)
any ideas?
[grammer check]
GinoEJ253two is offline   Reply With Quote
Old 12-16-2003, 07:48 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Yep. One of mine touches the intake side of my turbo. PITA if u ask me.
Wedge is offline   Reply With Quote
Old 12-16-2003, 08:44 PM   #3
Unsung Boxer
Member#: 37196
you can bend them a little bit simply by unbolting it from the mounts, and bending it across a long distance.
if you try to bend it across a short lenght, it is more likely to kink or snap.
We do it all the time in our shop.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 12-16-2003, 11:11 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I took the mounting brackets off the intake manifold. You can get a little more room that way.
lotusTT is offline   Reply With Quote
Old 12-17-2003, 09:38 AM   #5
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default SS lines
I personally would go with SS lines, it looks really clean and will solve your problem.
Joshua
yebokmj is offline   Reply With Quote
Old 12-17-2003, 05:25 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Re: SS lines
Joshua
Ooh, what kind of lines are those? Where can you get them?
Old 12-17-2003, 06:19 PM   #7
yebokmj
Member#: 2213
Brilliant Red
Default Kit
They came with the JC Sports kit back in the day. I'm sure they can be easily replicated.
Joshua
Old 12-17-2003, 10:02 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
That doesnt help...
Old 12-17-2003, 10:21 PM   #9
GinoEJ253two
Member#: 50464
1999 Impreza 2.5 RS
Thanks for the PIC!
Jc sports... pretty much defunc now
damn.. i could do that myself with some earls lines
i just don't know where to get the fittings for the bottom of the lines...
maybe I could just cut them from stock and use hose clamps...
but I don't know how much pressure that steering pump puts out.
if its too much for a hose clamp i could be in for some trouble...
Old 12-17-2003, 10:24 PM   #10
yebokmj
Member#: 2213
Brilliant Red
Default Top
The top line for one of them uses a hose clamp. Though that is probably on the return line that's not pressurized to the same degree. I thought Vishnu did these lines for their kits as well? Try contacting them possibly Or post up on the board for advice I know it's been discussed before.
Joshua
Old 12-18-2003, 09:25 PM   #11
yebokmj
Member#: 2213
Brilliant Red
Default Pics
Here is a close up of the lines at the pump. I found this in my existing photos I don't have one of it at the rack.
Joshua
Old 12-18-2003, 09:30 PM   #12
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
If anyone wants a set of these, I'm pretty sure I have them. They came with my used JC sports kit and they've never been used. I thought it might have been broken because one of the lines only has a slip on anodized connector, but from Josh's pics it looks like you just put a hose clamp on it. I'll take some pics in a bit.
Old 12-19-2003, 02:04 AM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Cool, im interested for sure, I could solve some potential problems with my kit with this
Old 12-19-2003, 02:22 AM   #14
sideways slut
Member#: 21085
2.5 rs-t
ya i wouldnt mind getting a set of these also
sideways slut is offline   Reply With Quote
Old 12-19-2003, 03:46 PM   #15
spcled
Member#: 5680
2001 2.5RS
Sedona Red
Look in the yellow pages for a local company that does hydraulics and associated plumbing and fittings - i had a company (dont remember the name) in the Albany NY area do me up a set up braided SS brake lines for my jeep before them were mainstream.
spcled is offline   Reply With Quote
Old 01-11-2004, 07:45 PM   #16
GinoEJ253two
Member#: 50464
1999 Impreza 2.5 RS
<bump>
yebokmj
can you take pics of the other side of the hoses.. thats the part thats being a bitch...
1st attempt
FAILURE at replicating...
the diameter if the pipe where is meets at the bottom (near x-member) is smaller on the positive pressure side... this means my hose clamps don't quite fit.. and tend to explode off while turning the wheel...
Old 01-11-2004, 09:15 PM   #17
yebokmj
Member#: 2213
Brilliant Red
Default Sorry
I don't have a digital camera and I wouldn't be able to get that good of pic anyways due to where they are located. Try lotusTT, he said he had some that he could snap pictures of.
Joshua
Old 01-11-2004, 09:26 PM   #18
GinoEJ253two
Member#: 50464
1999 Impreza 2.5 RS
thanks I'll PM him
Old 01-11-2004, 09:40 PM   #19
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Sorry guys, I forgot about this. I put some pics up at http://www.rit.edu/~krb5648/lines
One line has a larger screw on connecter and that red wierd slip on connecter on the other side.
The other has what looks the same size screw on connecter as the other line and a smaller connecter on the other end.
That's about all the info I have on them. They're still for sale, make me an offer if you want them.
Old 01-11-2004, 10:51 PM   #20
jeffsnyder
Member#: 10039
emailed ya lotusTT
Jeff
jeffsnyder is offline   Reply With Quote
Old 01-12-2004, 03:31 PM   #21
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Hmmm, I'll throw out a lowball offer of $50.
Drac9 is offline   Reply With Quote
Old 01-12-2004, 06:49 PM   #22
Tats
Member#: 5692
WTF? YES! I am
better than you!
The only line you can use a hose clamp on is the return. The pressure line holds way too much psi for a clamp tp hold reliably at all.
Tats.
Tats is offline   Reply With Quote
Old 01-12-2004, 06:55 PM   #23
GinoEJ253two
Member#: 50464
1999 Impreza 2.5 RS
i figured as much... well it was wishful thinking...
all those hose fittings on lotusTTs lines look like plumbers fittings
OSH here i come...
What are the thread sizes on the power steering lines? frayz Brakes, Steering & Suspension 7 11-05-2009 10:40 PM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
My 2005 Legacy GT's Power Steering went out in the middle of the road Eyeflyistheeye Off-Topic 30 02-25-2009 07:18 AM
My 2005 Legacy GT's Power Steering went out in the middle of the road Eyeflyistheeye Service & Maintenance 0 02-25-2009 01:27 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 10:58 PM
