Old 12-16-2003, 11:04 PM   #1
burnout555
Member#: 49108
Default Difference between fuel SYSTEM cleaner and fuel INJECTOR cleaner?
I just put an engine into my wrx that was in a rollover, so there was oil in it. I'm trying to get the best gas mileage out of it so I put some Turbo 108 fuel injector cleaner in it. Theres also a fuel system cleaner by Turbo 108. What is the difference?
What else should I do to my engine to clean it out. I'm going to put in NGK Iridium spark plugs, I'm hoping that will help too.
burnout555 is offline   Reply With Quote
Old 12-17-2003, 05:48 AM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
read the labels. they ought to tell you what the intended uses are.
nhluhr is offline   Reply With Quote
Old 12-17-2003, 06:51 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
I don't buy that stuff in a can. What I do is first use 1gal of methanol to a full tank of gas. This will remove any water in the fuel system. Then 1/2gal of toulene to a full tank of gas. This will clean any resin build up in the fuel system including the injectors. After the toulene treatment I change the fuel filter.
TMS
TheMadScientist is offline   Reply With Quote
Old 12-17-2003, 11:52 AM   #4
westy66
Member#: 4329
2005 LGT Wagon 5MT
actually there is no difference... they both are a waste of five bucks
westy66 is offline   Reply With Quote
motul engine and fuil injector cleaner XmikeX Service & Maintenance 4 11-11-2008 03:40 PM
Differences between AWD Systems in Auto vs. Manual: Button Transmission (AT/MT) & Driveline 6 11-17-2006 04:41 AM
Difference between Eibach Pro Kit and the SPD Eibach Kit? Arnie Brakes, Steering & Suspension 10 05-08-2001 01:23 PM
Whats the difference between FHI ver5 suspension and STI ver 5 suspension? MY99 2.5GT Brakes, Steering & Suspension 5 05-08-2001 05:20 AM
What's the difference between Sti wagon springs and Sti coupe/sedan springs? Robmat Brakes, Steering & Suspension 2 05-03-2001 09:56 AM
Message Board Statistics All times are GMT -4. The time now is 01:09 PM.
