Old 12-17-2003, 02:38 AM   #1
WRX-Mike110
Member#: 47831
Default Sti Block And Legacy Heads...
Does anyone know who has this setup on a wrx?
WRX-Mike110 is offline   Reply With Quote
Old 12-17-2003, 12:05 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
legacy like
1.8 legacy
2.0 legacy
2.0T legacy
2.0TT legacy
2.2 legacy
2.2T legacy
2.5 dohc legacy
2.5 sohc legacy
2.5T legacy (stx)
and the answer to it beining in a wrx .. no why would you do that
might very well be a 1.6 version too
Old 12-17-2003, 09:58 PM   #3
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
If you mean a STI 2.5 block and the legacy 2.2 heads, then that would be stupid. The legacy heads are about the worst possible heads you can use.
Old 12-18-2003, 09:04 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I know of a guy up in Canada who is putting some EJ22-T heads on an old EJ20 block. But only because he has the parts lying around from building his EJ22-T block with the original heads off the JDM EJ20.
And if you go that route for whatever unknown reason, you will need the EJ22 intake manifold as it is the only one that will fit those heads...
Old 12-19-2003, 01:28 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
and....the ej22T intake manifold blows, you have no room left for a TMIC.
subiekid is offline   Reply With Quote
wrx heads/sti block, current wrx heads ej20g 4banger4dr Built Motor Discussion 6 11-14-2009 03:55 PM
Short Block, Long Block and Cylinder Heads @ Slowboy Racing! Built Industries MAIC Vendor Classifieds 4 06-02-2009 01:57 PM
FS built short block, and seperate heads, sti browniesti04 Engine/Power/Exhaust 13 09-18-2007 10:01 PM
Looking for STi Short Block and 1 Head. Nasty_STi Private 'Wanted' Classifieds 3 08-13-2006 10:48 PM
STi block and WRX heads??? RS22b Subaru Conversions 13 02-11-2004 07:12 PM
Message Board Statistics All times are GMT -4. The time now is 03:09 AM.
