Old 12-17-2003, 04:26 AM   #1
cybin
Member#: 48667
Default SRS Airbag light came on. How do I reset?
I've got a 1997 Outback sport. I just installed a new steering wheel out of a 2.5RS. I reused the original airbag that came with the car and installed it into the new steering wheel. I must have tripped a sensor as when I hooked up the battery and started the car the light stays on.
I'm wondering how to reset the light.
I tried pulling the airbag fuses. Maybe I didn't do it right?
I tried resetting the ECU. No effect.
I'm wondering if there is a way though the computer to clear the codes.
Thanks,
-Cybin
cybin is offline   Reply With Quote
Old 12-17-2003, 05:08 AM   #2
nate49509
Member#: 22452
2016 WRX
Are you sure that you plugged the airbag connector in. Also you may want to double check all your fuses.
nate49509 is offline   Reply With Quote
Old 12-17-2003, 11:22 AM   #3
cybin
Member#: 48667
I'm going to have to double check the connector. Although it did give a positive click, at least I thought.
-Cybin
Old 12-17-2003, 02:20 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
It may not accept it... I remember that one of our local dealers, the owner bought a crashed 99RS to rebuild for his own use...
He was going to use the 98RS airbags (which were never used) cause the 98RS was a rally car... but they wouldn't plug in properly...
I'm not sure what was the problem or not..... I guess Subaru switched the design a bit...
He was pissed cause now he had to buy 99 airbags to have the car pass safety.....
I'll look in the 99 manual.. to see if they say anything from the standpoint of the airbags...
Robin
Robin2 is offline   Reply With Quote
Old 12-17-2003, 03:21 PM   #5
cybin
Member#: 48667
I'm actually using the original air bag that came with the car.
I read at the site listed below that in 1998 they switched to a de-powered airbag system. Thats why I didn't use the one that came with the steering wheel.
http://www.cars101.com/impreza_archive97_98.html
Old 12-18-2003, 10:43 AM   #6
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
The driver side SRS module is the same, only the passenger side is differant.
Did you push in the green tab on the connector? That is a double lock that will set a code if not depressed. It will not stay in memory if you fix the problem so you do not need to clear the computer afterward.
SubyTechMaster is offline   Reply With Quote
Old 12-18-2003, 01:20 PM   #7
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
If your only worried about the inspection, just pull the airbag bulb in the dash, but thats only a temporary solution that needs to be fixed sooner or later. Sooner would be better since later may be too late....
evo2rex is offline   Reply With Quote
Old 12-20-2003, 11:40 PM   #8
cybin
Member#: 48667
SubyTechMaster wins. Green tab was not pressed in. Airbag light went off right away.
Thank you very much.
-Cybin
Installed Aftermarket Seats, airbag light is on, how do i fix it? 1FSTREX Interior & Exterior Modification 15 07-06-2011 03:35 PM
SRS Airbag Light stays on during prolonged cold starts. da-chaz Service & Maintenance 4 01-31-2008 01:08 PM
airbag light came on attitude Service & Maintenance 5 12-16-2006 03:09 PM
AirBag light came on after this, need help guys! orwrx Electrical & Lighting 4 05-06-2006 10:05 PM
airbag light came on???? I am b Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-16-2001 05:05 PM
