Old 12-17-2003, 08:15 PM   #1
Vanagon_S
Member#: 49717
1987 Vanagon
Default 02 WRX engine vin tag question
I just bought an 02 WRX engine and I'm trying to figure out if it is what the guy says it is.
There is a VIN type part number tag on the left head, near the transmission. The tag has a barcode and this number:
EJ205AW3B9 - 1E5 - 8279
I'm guessing that the EJ205A is the engine... but are the last 4 digits the last 4 digits of the VIN?
BTW, the transmission decal reads: 7Y - TY754VN2BA
Here's a pic of the VIN plate the guy claims the engine came from.
I'm trying to figure out if the guy did a bait and switch on me with a JDM. He claimed it was a US version 02 WRX w/12k
Thanks!
Vanagon_S is offline   Reply With Quote
Old 12-17-2003, 09:15 PM   #2
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Its a early version GDA you can tell by the Vin part that says GDAAYXX. The A after the GDA would tell you its a Ver I GDA model! Also I think the last year for the 205 (I might be wrong) is 00'. As I have a STi 01 and it has a 207 in it. I am not sure what you are asking but look on the timing belt cover as in your facing the front of the engine on the right on top of the timing belt cover there should be a sticker silver with something to this nature on it 10 which would indicate at 100000 km change the belt!!!! If there is a sticker there I would assume its a JDM if not its probable a USDM!!!
My IME is not working but it will say 10 with kanji beside it. I am assuming the USDM engines would not have this sticker!!!
DuoMaxwell is offline   Reply With Quote
Old 12-18-2003, 05:07 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
Default Vin
The vin matches a us wrx 5MT 4 dr sedan
first 3 = JF1 = passanger car FHI made
4th digit = G = Impreza
5th digit = D = 4 door sedan (G = wagon)
6th digit = 2 = 2 liter AWD turbo (6=2.5 L awd)
7th digit = 9 = wrx (8=outback, 7=RS,5=TS)
10th digit = 2 = 2002 MY, (3 = 2003)
11th digit = G = 5mt full time AWD (H=AT4 full time AWD)
12 - 17 = from 500001 = 4dr sedan, (from 800001 = wagon)
The engine code is EJ205AW3B9
EJ=4 cyl
20 = 2.0 L
5= MPI turbo
A = US federal and California exhaust regs
W=MT
3= minor change 3 applied
B9=digits 9-10= detailed specs see parts catalog for details
Model number on vin plate
GDAAY8D
G=Impreza
D= 4door sedan (G=wagon)
A= 2.0 L AWD turbo
A= initial minor change
Y = Left hand drive US and Canada
8= WRX (4=TS, 6=RS,7=Outback)
D= DOHC B MPI 5 speed MT AWD
(R= SOHC MPI 4 speed AT, P= DOHC B MPI 4 speed AT, J= SOHC MPI 5 speed MT AWD)
Hope that helps.
Larry
hotrod is offline   Reply With Quote
Old 12-18-2003, 06:29 AM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
If he did it wouldn't be a bad bait n' switch. The JDM WRX motor has the nice heads
mr2guru is offline   Reply With Quote
Old 12-18-2003, 11:54 AM   #5
Vanagon_S
Member#: 49717
1987 Vanagon
Default last 4 digits...
So, can anyone verify if the last 4 digits of the engine code sticker match the VIN plate?
Meaning, that the last four, "8279" of the barcoded label on the head should match the VIN tag right?
If not, the tag would be from another car?
It looks like the VIN tag reads "8497"...
Not that it matters that much, but the guy is a little flakey and still owes me an engine harness to the ecu.
02 rs tranny on 02 wrx engine simprezl25 Transmission (AT/MT) & Driveline 0 09-22-2009 01:22 PM
doing a 02 rs to 02 wrx swap. have a question simprezl25 Subaru Conversions 0 06-21-2006 02:11 AM
02 WRX engine in a 98 L sedan? AlbanianImpreza Subaru Conversions 1 07-01-2003 08:00 PM
what are the 02 wrx engine specs Otaku64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 06:35 PM
WRX Engine Warm-Up Questions masterwoo Service & Maintenance 11 01-26-2002 04:06 PM
