Old 12-17-2003, 11:32 PM   #1
xtorted-legacy
Member#: 19568
1995 Impreza L
Brilliant Red
Default EJ22T header question
Alright, i would like to swap a Ej22T in to an older impreza coupe. My question is, should i use a standard 2.5L aftermarket header(like twe or boral) and get a custom uppipe/downpipe made(see my thread about the use of my t3/t4 garret turbo). I would need a these pieces fabricated anyhow. or should i go with aftermarket wrx header?
xtorted-legacy is offline   Reply With Quote
Old 12-18-2003, 09:10 AM   #2
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
My vote is either use the stock EJ22T header (flows pretty good) or an aftermarket WRX one (bolts right up). Then you only have to worry about your up-pipe and down-pipe.
legacy92ej22t is offline   Reply With Quote
Old 12-18-2003, 02:31 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
http://www.cobbtuning.com/tech/exhaustdesign/index.html
read this and you decide where to spend your money...
Old 12-18-2003, 03:10 PM   #4
xtorted-legacy
Member#: 19568
1995 Impreza L
Brilliant Red
I personally would use the TWE ewual length header because of its equal lengths = less turbulance and its 4-1 merge collector = even less turbulance. But does a header for a 2.5L phase 2 fit an EJ22T?
Old 12-19-2003, 10:11 PM   #5
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
The 2.2T and 2.5L both have dual-outlet heads, so I don't see this as a problem. And don't some wrx guys use the n/a bloack built up with stock wrx headers (which are the exact same header as the 2.2T)?
2.5GT is offline   Reply With Quote
Old 12-21-2003, 12:46 AM   #6
Unsung Boxer
Member#: 37196
Wow, can't believe no one caught this. You cannot just use a WRX header as it will run into the crossmember on the Impreza.
We call this the Turbo Xmember, and NA Xmember. Each has to be used w/ its respective header.
The reason that us AFI guys are using 'custom up pipes' is so that we dont have to remove the NA Xmember.
IF you want to use the WRX header, you will have to pull out the Xmember and swap in a Turbo Xmember.
This can be found on a Turbo Legacy or a WRX. Both bolt up to the GC8 Chassis, and runs about 150 bucks new. It is kinda a pain to swap it out though, I believe you have to pull the engine.
If you want custom up pipe, you can use a stock RS header or Aftermarket Upgraded one. www.uniquemotorsports sells the up pipe for 220 bucks. You will then need his downpipe, and have the missing portion of exhaust put in.
Hope that helps.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 12-24-2003, 02:02 AM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
well i would assume that if he is doing a 2.2t swap that he knows he needs to use the wrx/leg turbo x member.
just get a borla header for the wrx, they are cheap and produce good numbers.
subiekid is offline   Reply With Quote
91 legacy ej22t header and downpipe fitment? WRX parts? boostedballs Pre-2002 Factory Turbo Powertrain 8 02-22-2008 10:30 PM
More EJ22T Hyrbid Questions seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 5 03-11-2003 05:32 PM
More EJ22T Head Questions subachad Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-18-2002 12:26 PM
EJ22T Wiring Question AKGC8 Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-04-2002 05:31 AM
EJ22T conversion questions... Fitz Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-14-2001 09:56 PM
