Old 12-18-2003, 07:06 PM   #1
HJ (Indy)
Member#: 11776
Default Swap up & running! Pic's
Im using a Cobb 2.5 built shortblock that I had in my WRX for a couple years but it still has good compresion, Ver7 heads,6-speed,Brembos,R180 rear diff,vf39 for now,ver 7 RA ecu.,GD front & rear crossmembers, US STI quick ratio steering rake
Thats most of the conversion parts.
http://community.webshots.com/user/hankw999
HJ (Indy) is offline   Reply With Quote
Old 12-18-2003, 07:26 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Are you using the r180 from a gdb impreza. If so are you using the axles from that car too along with the hubs and brembos pictured. Or did you use gc8 r180 axles with gdb hubs and brembos. I was always told the rear axles are too long for gc8's so you'd have to use gc8 axles to fit. thanks for any help.
Also what suspension are you running. Any rubbing with the rims and tires, im assuming 225's.
Soon2Bgreat is offline   Reply With Quote
Old 12-18-2003, 10:43 PM   #3
annointed
Member#: 5960
FXT [email protected] 93 oct
NSX 450 whp SC'd (93 oct)
Default Re: Swap up & running! Pic's
You, sir, are a total f*cking animal.
Let me wipe the drool off...and I thought I had some crazy whips...
annointed is offline   Reply With Quote
Old 12-19-2003, 11:53 AM   #4
HJ (Indy)
Member#: 11776
Using the GDB big axles with hubs. No the axles arnt to long. They dont bottom out. Ther is only a small difference in track with on the GDBs. The only thing that really needed modified is the rack it is a diffenent spline than the GC. I used a GD steering yoke cut & welded to the GC yoke.
Old 12-21-2003, 01:55 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I like your style. I would love to go with a shorter rack but I lack the skills to make it fit.
-Jon
Old 02-16-2004, 10:10 PM   #6
serious
Member#: 22879
So are you using the new/wider track front and rear or did you retro fit the need parts to use the original track?
Thanks
Brent
serious is offline   Reply With Quote
Friends Supra up and running. Pics & vid japslapr Proven Power Bragging 117 06-04-2007 04:04 PM
RS with WRX swap up and running. AzNStiImpreza Mid Atlantic Impreza Club -- MAIC 49 08-11-2005 03:05 PM
RIM Auto Cross Course Up & Running .... makofoto Southern California Impreza Club Forum -- SCIC 7 05-06-2005 07:11 PM
What UTEC map should I run with an UP & DP, but stock catback? 03WRXMA Engine Management & Tuning 6 09-12-2003 11:35 AM
HAHAH...Finally - It's up & running,,, wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-02-2002 02:41 PM
