Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 12-19-2003, 04:47 AM   #1
Vicville
Member#: 50874
98 Outback Ltd
Default '98 OB piston slap - 2.5 AT
I had a service done recently by an independent mechanic who used to work for Subaru ("master mechanic") and told me that I should be using different oil. Specifically, he said, a formulation of 15W40, is the best way to deal with the chronic piston slap...hmmm... So I'm thinking: that's the same oil specs for my Ford Diesel F250 pickup. Seems mighty odd to me. Anybody else heard of this 'solution' for Subaru piston slap? One more thing: he says that the timing belt should be changed, despite my low mileage, because they "just go kaput, and fry the motor." I know what timing belts failure can do, but I thought that the problem with these '98s was not so common, and that it involved the tensioner, with some warnings first.... Suggestions? (I bought this car new; it's got relatively easy miles on it.) thanks
Vicville is offline   Reply With Quote
Old 12-19-2003, 06:55 PM   #2
b-o-b-s
Member#: 50148
2004 sti
jbp
Post ?
i agree with you about the oil. it sounds very odd. i work at a subaru dealer and i have never herd of that oil combo before. as for the t-belt i bet hes trying to make another buck of of you.
b-o-b-s is offline   Reply With Quote
Old 01-07-2004, 07:30 PM   #3
Mike Rockefeller
Member#: 52154
1998 Outback Wagon
Consider changing the timing belt tensioner. When it is weakened , the tensioner will knock up against the engine. It leaves a dent in the tensioner around the little piston. A new tensioner cost me $140 us, and replace the timing belt too . ?? Does the backside of the timing belt look torn up ? If so , take off the belt guide over the center crank and throw it away. Per Subaru dealer mechanic.
Mike Rockefeller is offline   Reply With Quote
Old 01-15-2004, 06:43 AM   #4
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 01-27-2004, 12:30 AM   #5
doctor_evil
Member#: 11148
Thumbs up
Why not try the 15W40? Heavier oil, and if you are in lotusland, you don't have to worry about the oil getting too thick in the cold.
We have a '98 OB also, and have the same piston slap issue. I'm sure you know about the whole story about the "need to warm up" and how "tolerances improve when warm". My wife is chronically running late, and she would just start the car and give'er - not so good. So I got her a remote starter, and now she always starts it early - she gets a warm car, and no piston slap.
But why not try? It's not going to hurt
Dave
PS I run 15w40 in my Datsun roadster all the time - it has issues with timing chain tensioners, and the heavier oil stays in the tensioners a little bit better that 10w30
doctor_evil is offline   Reply With Quote
Old 01-27-2004, 02:22 PM   #6
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Miss my '69 Datsun SRL 311 - sniff!
1 Lucky Texan is online now   Reply With Quote
possible piston slap or knock at cold start?? Flyin_Hayn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-31-2009 04:57 PM
Yes another which piston thread...2.5 hybrid with 280s Wrx_Fan_0717 Built Motor Discussion 3 09-29-2009 04:55 PM
Pistons for 2.5 XT Stolis Built Motor Discussion 3 05-09-2009 10:45 PM
are 2.2 pistons and 2.5 pistons the same size as far as bore goes? azn2nr Built Motor Discussion 9 11-08-2006 06:53 PM
100mm coated JE pistons and 2.5 short block SubaSonic Private 'For Sale' Classifieds 6 12-31-2003 10:53 AM
