Old 08-30-2000, 02:54 PM   #1
Swivel1000
Member#: 1168
2004 Jeep Grand
Cherokee Limited 4x4
Post Why are KYB/AGX's so cheap?
Im curious why you can get a set of KYB/AGX adjustables for like $400...and basically every other strut set out there i see is in the range of $1200-$2000 ???
And ive even heard good things abou the KYB/AGX's..
Thanks
Matt
Swivel1000 is offline
Old 08-30-2000, 03:06 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
they are a great option if you can't afford the coil over set ups...
they worked really, really well...
but...
they are $100 a corner... and um... well.. to be honest... i blew one out completely. yep. only had them on for mere months and completely blew 1 of the rears...
so you kind of get what you pay for... but at $100 a corner, you can easily buy another one...
j.
Subie Gal is offline
Old 08-30-2000, 03:06 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
You're comparing apples to oranges, that's why.
First of all, the AGX is actually quite unsophisticated. It is a dual tube shock, which means that the actual piston volume is small relative to the strut's external diameter. (Larger pistons equal more precise control.) It also means that it is prone to foaming as well, since the fluid is under very low pressure compared to a monotube shock. Finally, the AGX utilizes a linear damping rate which allows for unsophisticated and inexpensive damping.
That said I'm very happy with mine-- good shock for the money. The danger is paying big bucks for unproven struts... but there is a reason the Ground Control coilovers with AGX struts are <$800 and Ground Control's own struts makes it closer to $2000.
Read some modern chassis tuning books, they'll tell you all about shock damping... Older books aren't nearly as valuable because major inroads have been made in the last few years.
(by the way, this thread should be moved to the technical forum. )
[This message has been edited by ColinL (edited August 30, 2000).]
ColinL is offline
HTML code is On
Why are 05 FXTs so cheap? Big_Hitter Texas Impreza Club Forum -- TXIC 7 05-09-2006 08:40 PM
Why are my AGX's so STIFF? erikkellison Brakes, Steering & Suspension 27 04-25-2005 05:59 PM
why are these turbos soo cheap? deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-12-2005 03:21 PM
Why is STi insurance so cheap? ha-evolution STi Forum Archive 30 07-19-2003 06:53 PM
Why are WRC headlights so cheap?? JAMES_WRX03 Interior & Exterior Modification 9 04-16-2003 11:21 AM
