Mid Atlantic Impreza Club
Old 12-21-2003, 02:20 PM   #1
lucien2
Member#: 1519
1998 Volvo V70R
Unhappy New Subie sooner than later?
No heat coming home from Mom's house just now. Then the temp guage went through the roof. I pulled over. Coolant is cool but the overflow reservoir is empty. And making gurgle sounds. And there is coolant splatter all around it. And the thermostat is only 6 months old.
76,0000 miles on a Phase I EJ25(cue JAWS theme). I'm going to go add some filtered water to it and see what happens.
lucien2 is offline   Reply With Quote
Old 12-21-2003, 02:30 PM   #2
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Was the radiator hot? Sounds like a stuck thermostat if ya ask me. Did you use the oem one or an auto parts store one?
EvasionOfTruth is offline   Reply With Quote
Old 12-21-2003, 02:36 PM   #3
lucien2
Member#: 1519
1998 Volvo V70R
OEM. Nothing's hot. It took a LOT of water, though. It would probably take more, but I don't want to keep adding freezable water without getting some antifreeze in there, if it is truly that low. I wonder just how much I lost there around the reservoir.
Old 12-21-2003, 02:42 PM   #4
rhdude
Member#: 6637
2009 Acura MDX Sport
headgaskets... how do I know? been there...
it's not a stuck thermostat, I was told that, as were many others. I went into denial when people told me it was the headgaskets. Just suck it up and accept it... sorry man
what happens is air travels from inside the cylinder thru the leak on the headgasket, out into the coolant passage. this pressurizes the coolant, forcing it out of the block. it sends it into the over flow tank, and then sprays it out of the overflow tank all over the engine bay. this happened to me about once every two months at first, then happened about once a month, then once a week, then everytime I drove the car.
you can see the tear in the headgasket in the lower left hand corner. that little tear is where all the air travels through.
rhdude is offline   Reply With Quote
Old 12-21-2003, 02:46 PM   #5
lucien2
Member#: 1519
1998 Volvo V70R
Ughh....
As long as it hangs in for 2 more weeks, I'll pay someone to put the car back to stock and then trade it in. I was about to do that anyways (March or April).
Old 12-21-2003, 02:49 PM   #6
rhdude
Member#: 6637
it should hang for 2 weeks, I drove mine for a few months (boosted) on blown headgaskets...
good luck man... sucks to hear about it
Old 12-21-2003, 02:55 PM   #7
lucien2
Member#: 1519
1998 Volvo V70R
I'll drive wifey's OB this week, that should help. Then we're off to TX for a few days. 1st week of January I'll be in a position to put it in the shop for reversion to stock (struts, springs, exhaust).
edited for brain freeze.
Old 12-21-2003, 04:58 PM   #8
rhdude
Member#: 6637
struts and shocks are the same thing you mean springs?
Old 12-21-2003, 05:05 PM   #9
lucien2
Member#: 1519
1998 Volvo V70R
Yeesh. That was the install from Hades, no chance I'd get those 2 things confused. fixed.
Old 12-22-2003, 12:48 AM   #10
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Could be the water pump. It's harder to tell on these engines though. Can you see any leakage anywhere? Any sign of a drip, or steaming? Did you check the oil to verify if it the headgasket? Broken hose?
And now the biggie... how fast were you going? My fan fuse blew last week, and I boiled over. It was only because the fans weren't moving, and I wasn't going fast enough to cool the radiator. Replaced the fuse, and all is good. But it LOOKED like a headgasket issue.
Speedwagon is offline   Reply With Quote
Old 12-22-2003, 12:51 AM   #11
Speedwagon
Member#: 19681
Green
Originally posted by lucien2
Ughh....
I'll put it back to stock for you, if I can keep the strut assemblies..
Old 12-22-2003, 01:52 AM   #12
archbonr
Member#: 17666
08 Forester
I was having the same problem. Fine for the longest time, then overheating. First it was low on coolant, so I put some more in. Then there was bubbles coming up in the overflow tank. Replaced almost everything in the coolant system, then came to the sad conclusion that it is the gaskets. I have been driving with them like that (under boost) for just over two months now. I have all the parts, just haven't had the time. I am going to replace them this upcoming week though. I will post a picture of what mine look like then.
Nik
archbonr is offline   Reply With Quote
Old 12-22-2003, 07:31 AM   #13
lucien2
Member#: 1519
1998 Volvo V70R
Speed- I was going slow, varying between 15 to 40 mph, mostly 25mph or so.....I noticed the fans weren't running when I was out there checking it later....hmmmmmm.
As for the suspension bits, you might have yourself a deal there, bud. Lemme think about that one.
Old 12-22-2003, 07:55 AM   #14
Speedwagon
Member#: 19681
Green
I found that at 25mph on the capital beltway, I was heating up pretty good. I had to be going about 40 and over to get good cooling, without the fans working.
Go turn your A/C on and see if at least 1 fan comes on. If not, check the fuse. That might be the entire problem there.
Better sooner than later! rogue Off-Topic 12 07-19-2007 09:21 AM
So it was bound to happen sooner or later - Gay Divorce! Cjchaps Off-Topic 9 09-14-2004 01:52 PM
Ahhh...........well it had to happen sooner or later! Silver_SportTrac Texas Impreza Club Forum -- TXIC 5 05-05-2002 06:43 PM
well it was going to happen sooner or later dynoguy Mid West Subaru Owners Club Forum -- MWSOC 4 08-13-2001 09:21 PM
H6 engine will show up sooner rather than later Patrick Olsen Legacy Forum 5 12-12-1999 09:40 AM
