Old 12-21-2003, 03:13 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default USDM and Power Steering
What power steering lines did you use when you did your swap? I've got a 1996 L and my power steering lines do not mate up in the same way as the WRX does. Do any late-model power steering lines work or do I need the WRX lines? Will the WRX lines bolt up to my L rack ok?
-Jon
Old 12-21-2003, 03:32 PM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Any lines that have a remote reservior should work. You will need to fabricate a bracket to hold it in place. You should be able to use either Forster or WRX lines.
Z
Zephyr is offline   Reply With Quote
Old 12-21-2003, 04:40 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Which cars came with the remote reservoir? Foresters from what year?
Thanks,
-Jon
Old 12-21-2003, 06:31 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Im not sure of this, but I believe that the two lines flip around somewhat between model years. When I rebuilt my pump, I was going to just swap in an RS one, but ya the brackets are in different spots AND the lines are the opposite to how they connect with the power steering rack.
But a good solution might be some custom braided steel lines, those used to come on some turbo kits for RS's, and someone had a pic of them on one of the other forums... Looked like a good idea, cause you could use it to get all those lines out of those way rather easily.
Old 12-22-2003, 09:36 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
That is a good idea, except I need the fittings at the power steering pump. My L pump just used hoseclamps to attach but the WRX uses a banjo bolt.
-Jon
Old 12-22-2003, 09:56 AM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
So get the WRX PS lines why go half assed on items like suspension, steering and brakes. I know the Forester ones work and I know the WRX ones work as well. If you are gonna go and pull them from a junkyard you should be able to tell just by looking at them if they will work or not. Being that the Forester and the Impreza come off the same line the steering system is almost the same.
Z
Old 12-22-2003, 11:53 AM   #7
Aspen_2.5RS
Member#: 3310
I used the wrx lines and wrx reservoir on my swap (with L steering rack).
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 12-22-2003, 07:43 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The lines run $180 brand new at my cost (which is considerably better than retail). I'll have to see if I can source some at a yard tomorrow.
-Jon
Old 12-22-2003, 09:05 PM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Jon..
I am also using the WRX lines..and resevoir...with a RS rack....luckily my engine had that on it already...bolted right up..
Bill
Old 12-26-2003, 09:16 PM   #10
scoobydrew06
Member#: 32951
a lil off topic, but do you guys know about what steering racks are compatible w/ what models? I have a 93 L and the dealership says i need a new rack due to the loss of my power steering.
scoobydrew06 is offline   Reply With Quote
Old 12-26-2003, 11:49 PM   #11
Aspen_2.5RS
Member#: 3310
This might not be too much help, but I can pretty much guarantee that a WRX rack won't work unless you modify (probably by cutting/welding) the universal joint assembly for the steering. The splines on the wrx power steering rack were different than the ones on my 95 L.
Cam
USDM WRX Power Steering Rack into 95 Impreza 1.8L Xeno Subaru Conversions 11 03-11-2005 04:32 PM
wrx radiator, condenser, ac compressor, alternator and power steering pump Barticus Private 'For Sale' Classifieds 5 07-30-2004 04:30 PM
2002-04 WRX usdm LHD power steering lines underground-mpyre Private 'Wanted' Classifieds 4 07-07-2004 07:56 AM
Adjusting steering wheel and Power STeering noises FatCatTurbo Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-06-2003 09:33 AM
Changing WRX clutch and power steering hose question Ken-gv Service & Maintenance 1 07-29-2003 03:04 AM
