Old 12-21-2003, 11:44 PM   #1
Woody643
Member#: 34739
03 WRX
Silver Metallic
Default Voltage Regulator / Lights dimming issue
Hey,
I am having a dimming lights issue with my my03 wrx. All of the lights (headlights, dash, dome map, and even the headunit) dim whenever there is a bass note played through my conservative system. Dimming starts when the volume is only about 1/3 up, and gets progressively worse from there. This is with the engine on at idle. Here is what I have:
Ground mod 8 ga. wiring
Alpine headunit
MTX Thunder 6304 amp, 37.5 x 2 (front components)
325 x 1 (sub, Meniscus sw1084 sealed box)
Power and ground 8 ga. wiring Ground is connected to the rear seat belt anchor.
That's it! As you can see, it's nothing special. I've heard that a cap doesn't do much, and an alternator is expensive. The system sounds fine, but I think that at higher volumes, the voltage drop prevents the amp from delivering all of the bass it is capable of.
I've also heard that the speed of the voltage regulator determines how fast the alternator ramps up voltage to cover the quick depletion after the bass note occurs. Are the regulators internal or external from the alternator? Has anyone ever replaced theirs with an aftermarke one? I'd hate to spend the money on a high output alternator if all I really needed was a faster regulator. Any ideas???
Frank
Woody643 is offline   Reply With Quote
Old 12-22-2003, 12:29 AM   #2
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
Voltage regulators are inside the alternator. I can get you a high output unit that should take care of most if not all of the dimming at idle. Let me know through PM if you're at all interested.
Chad
ruiner is offline   Reply With Quote
Old 12-22-2003, 08:06 AM   #3
grknss
Member#: 44592
2004 WRX STI
Platinum Silver Metallic
A high output alternator will definitely fix that, although it is pretty $$$$ look into Batcap's I am using a setup they suggested and I have had no real dimming issues and I am running a bit of a higher power draw in my system.
my vehicle voltage (running at idle) will dip into the 11.9 range with the system up and a lot of bass. while driving 13.5 is about where she stays steady and crusing 14.1/14.5
if you'd like I can post what my system is to compare
grknss is offline   Reply With Quote
Old 12-22-2003, 11:02 AM   #4
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
With the high output alternator I sell, I am always over 14 volts even with the system at full crank at idle. Light still dim slightly but i do not lose any voltage what so ever.
Chad
Old 12-22-2003, 01:34 PM   #5
grknss
Member#: 44592
2004 WRX STI
cool, how much is it and will it fit an STi what is the output compared to stock?
I maybe interested in it
thanks
Old 12-22-2003, 04:38 PM   #6
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
Send me a PM on pricing, output of STi stock is 90A, my unit is 150A. Stock WRX is 75A. Fitment is fine for both STi and WRX. Also fits GC Impreza.
Chad
Old 12-22-2003, 04:46 PM   #7
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I am not trying to steer anyone away from Chad as what he is offering can be of siginificant help; but you may consider upgrading your "magic 3" wires first (upgrading as in using a larger gauge and better quality wire). There have been numerous discussions on the benfits of this around the web and has completely fixed the 'lights dimming' problem of some folks. And besides, it is a very cheap upgrade that really should be done no matter what other electrical upgrades you perform. Here is the brief explanation of which wires are the ones to replace...
1)Neg batt to chassis
2)Neg batt to engine block
3)Alternator body to chassis
offset
offset is offline   Reply With Quote
Old 12-22-2003, 08:30 PM   #8
grknss
Member#: 44592
2004 WRX STI
I agree that the gauge of wire used is important, I am already running sufficient gauge wire for my application
Old 12-22-2003, 11:30 PM   #9
Woody643
Member#: 34739
03 WRX
Silver Metallic
Offset,
I've heard of the "big three", and have done the ground mod, to include
Negative batt to body, Negative batt to block, and block to frame/body.
Someone on another board mentioned to add another wire from your alternator output to positive battery. Stock, there already is one, they were just saying to add another for less resistance.
Has anyone done this yet?
Frank
Old 12-22-2003, 11:39 PM   #10
ruiner
Member#: 20784
2002 Impreza WRX
WR Blue
Magic 3 wires are definitely important, I don't take it as you steering anyone away from me I actually want to do that to my car, but have been too lazy to do so.
Chad
Alternator or voltage regulator? sorrowfulkiller Electrical & Lighting 6 05-18-2013 05:23 AM
FL: Apexi Super ground system/Voltage regulator QwikRex Private 'For Sale' Classifieds 47 10-01-2004 01:03 PM
2003 New SE Lights Dimming Issue tether Legacy Forum 11 11-14-2002 10:18 PM
Voltage Regulator Revision Mid West Subaru Owners Club Forum -- MWSOC 4 06-27-2002 12:50 PM
Voltag Regulator? callawayv Service & Maintenance 1 01-12-2002 10:48 PM
