Old 12-22-2003, 05:16 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default What did I do?
I have my USDM EJ20 sitting on my USDM WRX crossmember. Everything seemingly bolted together fine. However, I can see that my engine and transmission are farther forward than they should be. If I look at the transmission mount, I can see that it is slanted as though the tranny is too far forward or perhaps at an extreme angle caused by the engine being too far down in the front. To further reinforce my worry, the pitch stop mount will not go back in. It needs to be about .5 inches longer (just about the exact distance the transmission appears to be forward). The problem with that, though, is that the engine mounts are sitting right in the crossmember. If I were to just jack the front of the engine up to where the pitch stop would go back in, I would think that would put a great strain on the pitchstop mount and the firewall. I don't know if this is related or not, but the turbo inlet hose has a fitting on the very top and that just barely touches my JDM STi Ver II hood.
How does an engine get too far foward with no way to get it back? I looked at my old engine mounts and the studs are offset front to back but I fear that if I were to completely remove both engine mounts rotate them and reinstall on opposite sides (if this can even be done) then the engine would be too far back.
-Jon
Old 12-22-2003, 05:20 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Well i don't know about the pitch stop. But gdb engines do sit further forward and up in gc's. There shouldn't be much room at all btwn the radiator either. I know with my gdb engine the airbox (not quite the inlet hose, but close enough) hits the hood, i had to remove the vent to make room, even then it pushes up the plastic a little. Although my pitch stopper has always fit when i disconnected and reconnected it.
P.S. did you tighten down the tranny mounts yet?
Soon2Bgreat is offline   Reply With Quote
Old 12-22-2003, 06:19 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Jon...
Check the Clutch inspection plate on the bottom..had to take mine off to get it to work....Its the one on the bottom of the engine and the flywheel sits inside of it....that sounds like just the amount of room that you need to take up the slack...Hope that helps..
Bill
Old 12-22-2003, 07:42 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Hrm... I spent an extra hour trying to fit that inspection plate when the engine was almost bolted in. I thought you had said that it was interfering with your RS clutch but maybe I'm wrong. It didn't look like it was hitting anything. For the record, I'm using a WRX transmission, engine, flywheel, clutch, and crossmember.
I don't know if I got it or not, but it is all bolted in. I think it just needed to be jiggled and tweaked to get it all in there right. It is still not quite perfect, but it is now close. I unbolted the transmission from the transmission crossmember and also loosened the transmission mount bolts. Then I jacked up the middle of the transmission a little and then jiggled things around. Then I jacked the engine up a little and jiggled it around too. While it was up I bolted in the pitch stop and then set things back down. This appears to have pulled things closer and I can take the bolt out of the ptich stop and get it back in. It is RIGHT at the edge of its movement though.
-Jon
Old 12-22-2003, 09:03 PM   #5
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
-Jon
OK That makes sense then...and you are right..I am using the RS tranny....next time put some grease on the dowel pins and the tranny shaft.......it makes is "slicker" ..
Bill
Old 12-22-2003, 10:49 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Are you using stock bushings, or like sti tranny/engine mounts and maybe some other aftermarket bushings?
Old 12-22-2003, 11:20 PM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
STi transmission mount and I think stock engine mounts. Cobb shifter bushings but that wouldn't make any difference.
-Jon
Old 12-24-2003, 01:49 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Try STI engine mounts and some crossmember mounts. That might help even it out too.
Old 12-24-2003, 11:01 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yup i think your engine mounts are on backwards ... but is that possible>?
Old 12-24-2003, 11:50 AM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I guess the easy way to check would be to remove the engine mounts on my EJ22 sitting on my porch and try to reverse them.
-Jon
Old 12-24-2003, 12:44 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whoa redneck .. engine on the porch?.. how many dogs?
Old 12-24-2003, 01:52 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Back porch! Nobody can see it. No cars on blocks at the moment, no dogs, no trailer.
-Jon
Old 12-25-2003, 01:03 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes if I remember correctly you can put the mounts on backwards
Old 12-25-2003, 02:50 AM   #14
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Uh oh, a moderator putting parts on backwards
Old 12-26-2003, 12:16 PM   #15
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Negative. I pulled one side and it is perfect. Things just got pulled out funny when we pulled the motor and I think it needs time to settle back in.
-Jon
Old 12-27-2003, 02:31 AM   #16
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
-Jon
GOOD! I was worried there for a sec...
so what did you do in this heatwave today? this is what i did... shukes24 Mid West Subaru Owners Club Forum -- MWSOC 44 07-17-2006 03:39 PM
My Photographer comrades. what did i do wrong?? 56k do not enter!! D-I-Z-Z-L-E Off-Topic 17 01-13-2004 11:45 AM
('93-'01) What did you do tonight? me? I got carjacked.. Prog Impreza Forum 111 05-13-2001 04:22 PM
('93-'01) POLL..what did you do with your letters after you debadged your trunk SuBaRu-ImPrEzA_RS Impreza Forum 42 04-27-2001 08:39 AM
What did I do?! MrX Mid West Subaru Owners Club Forum -- MWSOC 5 09-21-2000 08:12 AM
