Old 12-22-2003, 11:39 PM   #1
Boost4U
Member#: 16459
1998 2.5RS
Default Gas smells!
Here is my problem...
I just installed a TEC-2 on my EJ205 swap....I jumped the relay for the fuel pump to check the Vishnu rails and hoses for leaks......I couldn't find any. At least until gas started dripping out the gasket between the two sections of the exhaust manifold. I pulled the plugs, and they were very wet!! Somehow gas was injected into the cylinder.....the car was not power up, the Tec-2 was not powered. I should also say that the fuel system is setup with a Malpassi FPR, Vishnu rails, and 550cc RC injectors. The system is connected in parallel with the 2 return feeding into the 2 barbs on the regulator and then back to the fuel tank. I used my compressor to simulate fuel delivery under boost...about 20+ PSI. Only one side of the engine flooded with fuel.... Anyone have any ideas why this would happen? And why only on one side?
-Chris
Boost4U is offline   Reply With Quote
Old 12-23-2003, 05:14 PM   #2
Boost4U
Member#: 16459
1998 2.5RS
This is confusing me!
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 07:14 PM
2 newbie questions, Occasional gas smell and gas pipe wattpuppy Newbies & FAQs 0 10-31-2006 01:01 PM
gas smell TSB- repaired and still smelling it! SVX WRX Warranty Issues & SOA Problems 5 04-13-2004 07:33 PM
gas smell? tonic Newbies & FAQs 4 04-11-2001 10:53 AM
Exhaust gas smell in car... WRC666 General Forum Archive 5 03-03-2001 12:47 AM
