Old 12-22-2003, 10:03 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Default ej20g ecu troubleshooting
ok....i'm in need of some help defiining a flashing error code.
the light in the ecu blinks 1 long time followed by 6 short blinks. what does this mean? i looked all over yahoo, google, scoobymods, nasioc and i'm stuck
thanks
smacksube is offline   Reply With Quote
Old 12-22-2003, 10:26 PM   #2
smacksube
Member#: 4067
01 2.5 rs
ok, in case this site is slow or goes down...i can be reached at
shiva555@tampabay.rr.com
or
813-389-8011 - cell....thanks
please no prank phone calls
Old 12-23-2003, 06:11 AM   #3
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Slow blinks are the first number short quick blinks are the second number!!!
You have a cel of 16 which I have no clue what it means.
What mods have you installed???
DuoMaxwell is offline   Reply With Quote
Old 12-23-2003, 09:10 AM   #4
EJ25
Member#: 10768
Code ITEM
11 Crankshaft position sensor
12 Starter switch
13 Camshaft position sensor
21 Engine coolant temperature sensor
22 Knock sensor
23 Mass air flow sensor
24 Idle air control solenoid
31 Throttle position sensor
32 Oxygen sensor
33 Vehicle speed sensor 2
35 Purge control solenoid valve
42 Idle switch
44 Wastegate control solenoid valve
45 Pressure sensor – Pressure exchange solenoid valve
51 Neutral position switch
there is no code 16 that I can see, can you check the code again
long pulse - 10, short pulses =1
EJ25 is offline   Reply With Quote
Old 12-23-2003, 10:53 AM   #5
Structure828
Member#: 50488
1999 GC8 ej20g!
EJ25, ty for the post. Can you please tell Smacksube where you got this info from. The engine is an EJ20G out of a JDM 94 legacy turbowith an LSD. This is the last step, and the project will be complete. If anyone has any further info, links, or news about the ECU layout please send to me or Eric.
Structure828 is offline   Reply With Quote
Old 12-23-2003, 10:58 AM   #6
Structure828
Member#: 50488
1999 GC8 ej20g!
annointed
A member of the NASIOC said he was doing the same swap and had the ECU printouts and would fax them to you Eric. For all the pin-outs/error codes. Try getting a hold of him through his profile. I saw the info on 1 of your old posts he replied to.
Also, if ANYONE else has any info please let us know.
Old 12-23-2003, 11:30 AM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
like ya
Old 12-23-2003, 11:36 AM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
and i found this like while searching through google on "trouble code 16 subaru"
a legacy RS could be an 89-94 so this info should be credible
and all the other codes match up
http://autorepair.about.com/library/...bl-dtcs-89.htm
sooo looks like injector #3.. plug b44 pin 11
merry christmas
santa jaxx
Using an EJ20G ECU or EJ20G pinned standalone in place of EJ22T ECU impreza_GC8 Pre-2002 Factory Turbo Powertrain 3 10-30-2009 07:37 AM
ej20k ecu swap for ej20g ecu lJlDlMl Subaru Conversions 2 09-12-2009 11:04 AM
Mines flashed EJ20G ecu, and ej20G engine harness liberty2000rs Engine/Power/Exhaust 1 10-31-2006 12:54 AM
Wtb: Ej20g Ecu bbbwrx Subaru Conversions 11 02-23-2006 12:44 PM
EJ20G ECU pinouts smacksube Subaru Conversions 5 12-18-2003 03:07 PM
Message Board Statistics All times are GMT -4. The time now is 07:32 PM.
