Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 12-23-2003, 09:51 AM   #1
Rockin Ronnie
Member#: 37890
2009 Forester
Dark Grey Metallic
Default Will tire size and bolt pattern be same for 05?
I intend on acquiring a 2005 OBW when they arrive in Canada, presumably in the spring, and wonder if I can still use my 225/60-16s mounted snows? Will tire size and bolt pattern be the same for the 05 OBW.
Rockin Ronnie
2000 OBW
Rockin Ronnie is offline   Reply With Quote
Old 12-23-2003, 05:41 PM   #2
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
Yes. I have the new spec Outback 3.0R H6 which is already available here in Oz. The 2.5i rims/tyres are 16" 215/60 (the US always had 225/60 for some reason) and the H6 has 17" with 215/55. If it follows the previous spec (your current spec) then you should get the 225/60 16" for the 2.5i and a rim tyre combo of 17" possibly 225/55 for the H6 I suspect.
The bolt pattern and offset is also the same as for the previous (your current spec) Outbacks which is 5 x 100 pcd with an offset of 48mm.
SubaH6 is offline   Reply With Quote
Old 01-06-2004, 09:37 PM   #3
Caucazian
Member#: 51025
2004 Impreza OBS
WR Blue
Yes, the reason I say this is becasue the 03' and 04 OBW bolt pattern are different so I would imagine so on the 05'.
Caucazian is offline   Reply With Quote
Old 01-07-2004, 04:04 PM   #4
Rockin Ronnie
Member#: 37890
2009 Forester
Dark Grey Metallic
Default Why would they do that?
Does the last poster have more specific information.
Why would they change the bolt pattern in a carry-over model? Makes no sense whatsoever!
Ron
Old 01-11-2004, 10:46 AM   #5
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
That looks like a typo. He answered "Yes". The only questions I see are the inquiries about whether the bolt pattern is the same and if the 225/60-16 size will fit. That would indicate that he meant to say the 03 and 04 bolt patterns are not different. I wouldn't think they'd be different either.
ag
driven by guts inside!
AGscooby is offline   Reply With Quote
Old 01-15-2004, 06:42 AM   #6
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
Rally Medic is offline   Reply With Quote
Old 01-23-2004, 05:10 PM   #7
SubaH6
Member#: 38460
2005 Liberty 3.0R B
Obsidian Black
As I stated, the bolt pattern and offset are exactly the same as the previous model (your current model). The new model is available NOW here in Australia and my Outback 3.0R has the same 5 x 100pcd and 48mm offset as the previous model.
Old 02-05-2004, 07:54 PM   #8
Rockin Ronnie
Member#: 37890
2009 Forester
Dark Grey Metallic
Default Looks like 16" wheels but...
225/60s for base wagon?
Ron
Is the bolt pattern the same on the 08 as on the 07? WRBSTiBrett Tire & Wheel 1 10-31-2009 06:27 PM
05 STI bolt pattern the same as 06 STI ?? beans Tire & Wheel 1 12-05-2005 12:18 PM
Forester XT offset and lug pattern the same as WRX? jmaiken Forester Forum 11 12-04-2003 07:49 PM
Legacy/Impreza wheel bolt patterns the same? mwilliams Legacy Forum 4 06-11-2001 08:41 AM
offset and bolt pattern of older Imprezas? alastair Brakes, Steering & Suspension 2 04-01-2001 01:29 PM
