Old 12-23-2003, 11:32 AM   #1
jmaiken
Member#: 8506
04 Forester XT
Black -VF39, STi tmic etc
Default what else can cause the evap. emissions leak CEL?
I threw this code, took it to the dealer and they replaced the gas cap. I got it again and am trying to figure out what it could be.
I have recently brought my car back to stock (from a stg. 4). I wonder if I damaged the gasket to the gas tank access panel when I swapped my OEM fuel pump back in.
Anything else to look for?
jmaiken is offline   Reply With Quote
Old 12-23-2003, 11:56 AM   #2
wickedwrx
Member#: 23826
2002 impreza
No color it is invisible.
I think the gasket would be a good place to look at first if you had the gas cap replaced and you are still throughing that code.
wickedwrx is offline   Reply With Quote
Old 12-23-2003, 12:04 PM   #3
Full_Clip
Member#: 22218
Might as well go for it. But if the fuel pump gasket went bad or got damaged, shouldn't there be an odor of gasoline in the interior?
Full_Clip sniffs the carpet.
Full_Clip is offline   Reply With Quote
Old 12-23-2003, 12:10 PM   #4
SpeedracerX
Visiting NASIOC Timeout
Member#: 51110
2003 WRX
Turquiose Blue/Primer Gra
I threw the code, and the dealer had to replace a valve in the gas tank, after first telling me that I didn't twist the gas cap enough.
Have the dealer check the evap system in the tank. It's a pain, but it stopped the problem.
SRX
SpeedracerX is offline   Reply With Quote
Old 12-23-2003, 12:11 PM   #5
jmaiken
Member#: 8506
04 Forester XT
When I remove the gas cap I get the whoosh sound as the air pressure equalizes. Because of this I think the gas tank assembly might be okay.
I talked to a subbie guru today and he said it might be that the injectors need to be cleaned. He told me that he has seen this code after someone swapped back to OEM like I did. I guess the stock injectors can gum up after sitting unused for a while. He suggested a fuel injector cleaning service.
Any other ideas?
Old 12-26-2003, 06:51 PM   #6
jmaiken
Member#: 8506
04 Forester XT
Code came back, but then went away on it's own. Code is p0442.
Any other ideas?
Old 12-27-2003, 12:48 AM   #7
BADWRX
Member#: 3792
2002 6MT almost GDB
Fuel pump assembly gasket? I am getting the same code, and I am pretty positive that is what mine is.
BADWRX is offline   Reply With Quote
Old 12-27-2003, 10:55 AM   #8
jmaiken
Member#: 8506
04 Forester XT
what do you mean by the fuel pump assembly gasket? I don't remember there being a gasket on the pump.
thanks
what can cause the right bank to go lean??? STiGuy23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-01-2009 05:21 PM
The interview process, applying for a new job, what else can I do? Mud Pig Off-Topic 18 11-27-2007 02:41 PM
evap emissions leak gsteclipse33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-02-2005 12:07 PM
what can cause the stock ECu to pull timing? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-13-2004 08:47 AM
CEl after up pipe, did resistor what else can it be? bad resistor? fedrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-30-2004 04:57 PM
