Old 12-24-2003, 09:51 AM   #1
Davenow
Member#: 23676
Default STI 2.5 shortblock bolted into 02 WRX with 2.0 heads Worth it?
I am thinking of "accidentally" roasting a piston in the spring and going to the STI shortblock. I know this is a hair brained scheme, but I am just thinking outloud. I dont care about your opinions of the act itself, just how would it perform, what problems will I run into if I WERE to do it (there is only like a 1% chance I would)
I know the heads fow limit the HP, but I am looking to pick up low and mid torque.
Will it bolt right in and work? (obviously I would need to re-tune the UTEC right?)
Old 12-24-2003, 10:12 AM   #2
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: STI 2.5 shortblock bolted into 02 WRX with 2.0 heads Worth it?
Someone REALLLLLLY needs to do a search.....
Sorry... I'm RARELY the search nazi.... but it's only been discussed to death in the last 8 weeks..
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 12-24-2003, 10:24 AM   #3
Davenow
Member#: 23676
sorry man I hate to be the non searching noob, I havent been in the techincal forums in a while (not in earnest anyway)
Can you cliff notes it for me?
good or bad?
Old 12-24-2003, 10:56 AM   #4
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
It has been done with varying results. Some have just used straight up stock heads and few had them ported, most have retained the stock cams. The ones that have written on here and that I have pmed/talked to have been pretty happy with it on the street, very torquy. The ones with biggers heads have been pretty happy as well.
I am using the stock heads that I am porting, with upgrded springs and retainers from Axis. I have not final ised my cam plans but have been eyeing some JUN 264's.
For big power the heads are not really the show stopper the cams/valve trian are, not that having big port JDM heads or ported USDM heads would hurt. What sucks about the Cam issue is that the choices are minmal and expesive.
So it all really comes down to what you want to do with the car.
roybfr is offline   Reply With Quote
Old 12-24-2003, 11:00 AM   #5
subywrxwrblu
Member#: 9332
search for i-Speed, thier latest thread should help you.
subywrxwrblu is offline   Reply With Quote
2.5 RS swap in 02 WRX...What is needed? Tr2laozboi Newbies & FAQs 7 01-01-2010 11:11 PM
Feeler: 2.5 Motor for my 02 WRX Nitrousspeed Private 'Wanted' Classifieds 1 05-06-2009 12:31 PM
FS: stromung 2.5 TBE & Oem 02 wrx TBE ballaboy01 Engine/Power/Exhaust 4 01-08-2009 12:49 PM
04 6 speed swap into 02 Wrx with Sti swap drftwell Transmission (AT/MT) & Driveline 28 09-10-2008 09:22 PM
FS: Evo8 Seats Ready to bolt into 02+ WRX St0k3d Tri-State Area Private Classifieds 20 07-12-2007 03:03 PM
Message Board Statistics All times are GMT -4. The time now is 01:20 PM.
