#1 |
Member#: 4496
Vehicle:2009 Forester red |
i've been under the misconception that the r180 rear diff only came in the sti ver.7 and up. my friend overseas says it's not so because he just worked on a gc8 ver.5 RA sti and it also has a r180 rear diff.
what is the FD? is this r180 rear diff from the ver.5 something i can use when converting over to an sti 6mt on my wrx, and still be able to keep everything else out back?
#2 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
Ben. The R180 was used in GC8 cars. The Type RA's came with R180's mainly. Others had R160's. The rule of thumb you can use is that if the car had DCCD control on the Center diff it came with an R180 rear diff.
You can use any of he R160's or R180 diffs in your car as long as the Correct ring and pinion is installed. For A 6mt swap you can use either one... Clark |
#3 |
Member#: 18446
Vehicle:2002 WRX wagon psm |
The US STI has 180 as well, right?
I kept the R160, and although I've decided that with how much (little) hp/tq I'm making I'm probably not at risk of damagine my rear diff/spiders, my drag racing days are pretty much over. We don't have an AWD dyno here, but I'm guessing I'm 340-350hp at the crank. (12.8 @ 104) |
#4 |
Member#: 8785
SWIC
Yes. US STI has R180. Alot of people are using the R160 wih the 6mt at your power level and above without issue. In rally the R160 seems to fail and the R180 is a reqiurement. Shock is what kills it.
Clark |
#5 |
Member#: 2258
Vehicle:1999 gc8 ver7 6mt GT35R 504.7whp;) |
the final drive on most gc8 r180's will be 4.44. Some may have 4.11 but either way it won't be 3.9. It is much easier to use a gd one as it has the right fd, imo.
Ben if your doing this to a wrx i don't think it would really be cheaper to get a gc one as you'd have to change the fd, not to mention they're not much cheaper than gd ones. Keep in mind also you'd have to use the gd axles as the gc ones are too short. If you're going with the r180 i suggest just getting a gd one, unless you find a great deal on a gc one (free maybe, lol.) Good luck. ![]() |
#6 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
Your ratio won't match and you'll still need different axles. You'll basically have to change the same things that you are changing if you use the GD one, except you'll have to take the extra step of changing the ring and pinion.
#7 |
Member#: 4496
ugh... i was hoping to avoid changing the drive axles and hubs, but still be able to use an r180 for durability. scratch that plan
![]() another bonehead question... the rear 2-pot brakes from the ver.5 RA... will they fit gdb hubs? |
#8 |
Member#: 1581
They should fit GC hubs. I think you can do a hybrid axle to get around that problem. Use the r180 inboard and WRX outboard.
pm'd you |
#9 |
Member#: 4496
ugh... (past honda experience in my dark, shady past
) makes me shy away from hybrid one-off axles.for those of u who have converted to the r180 rear on your wrx... what have u done with the temp probe/sensor/thingy? |
#10 |
Member#: 1581
I'd say plug it or run an aftermarket tranny temp gauge into it. That would be pretty cool.
#11 | |
Member#: 24827
Vehicle:2005 GMC 2500HD 2008 Kia Spectra |
-Nic |
| Thread Tools | |
| Display Modes | |
| Spec B 6mt and r180 Rear Diff | foolio | Drivetrain | 9 | 08-10-2008 07:26 PM |
| How many North American WRC fans are there? | Kincaid Racing | Motorsports | 52 | 01-17-2006 11:46 AM |
| How many versions of the Utec are there?? | AK*WRX*2004 | Engine Management & Tuning | 5 | 02-01-2005 10:49 AM |
| How many kinds of rear spats are there? | GooseMan | Interior & Exterior Modification | 10 | 10-25-2001 10:34 PM |
| How many have had rear diff axle seals replaced under warranty?? | donjuan | Normally Aspirated Powertrain | 2 | 07-18-2001 09:33 PM |
