Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-24-2003, 07:23 PM   #1
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Default Shift Kit On an Impreza L??
I was just wondering if you could put a shift kit on an Impreza L. Would it be worth it. I don't know to much about AT's, so if you guy's could enlighten me that'd be great;
1. Would I have to get a special one, I know a lot of muscle car guys use them.
2. The car that it would be going on is tracked (road coarse) a lot, would this be an advantage/disadvantage, how so?
3. Is the install easy?
4. How much to they generally cost.
TIA.
Mike~~
N'CTRL is offline   Reply With Quote
Old 12-25-2003, 03:42 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What you mean a short shifter on an auto tranny? It doesnt work like that.
Old 12-25-2003, 11:03 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
He didn't mean a short shifter, he knows better than that
He's asking about a shift kit as in the modified valve bodies sold for GM's that firm up the shift pressure and change the shift points. Generally these have been available for the older hydraulically operated transmissions, the newer electronically controlled ones like the 4EAT are another matter. I'm not really familiar with the trans on the L ('95 right?) but I'm assuming it's electronic.
I haven't seen anyone offering them for Subarus but that doesn't mean they don't exist. It would be a limited market though.
Yes you would need one made specifically for that trans, they are not universal or interchangeable.
Old 12-25-2003, 02:45 PM   #4
N'CTRL
Member#: 29871
Metallic
Thanks mulder, and it's a '96.
Old 12-27-2003, 12:55 AM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
depending on the kit you go with, transgo, or a level 10 jobber. It can be done. the transgo kit is about 60 bucks. Tearing the trans apart is what will be expensive.
If you plan on keeping the car for a while, might want to do it....otherwise I'd just keep driving it.
Legacy777 is offline   Reply With Quote
Old 12-28-2003, 02:51 PM   #6
Olson
Member#: 51277
1991 Galant VR4
Blk
what is this transgo. a company? care to explain a bit
Olson is offline   Reply With Quote
Old 12-28-2003, 03:02 PM   #7
Legacy777
Member#: 4800
It's a company that makes shift kits
http://www.txchange.com/sk.htm#Import
Here's the one you would use
SK® RE4R01A
Nissan RE4R01A, RL4R01A Mazda R4AX-EL, Subaru 4 speed ECAT, Nissan – Infinity – Truck - SUV V8 RE4R03A, Isuzu Diesel JR403
1988up 4 speed with or without lockup
Corrects/Prevents/Reduces:
Planetary burnup; 3rd clutch failure; forward clutch burnup Soft 1-2 shift; 2-3 cutloose; Band burnout and low lube flow causing overheating and total burnup
Old 12-28-2003, 03:28 PM   #8
N'CTRL
Member#: 29871
Metallic
Thanks for all your help/info. Just a FYI, the car isn't a street car so I wasn't gonna be worried about daily driving, it's a race car.
Anyway, this past weekend it was decided that the car is getting a 5spd swap anyway.
http://forums.nasioc.com/forums/show...hreadid=475198
Thanks again for the info.
Mike~~
Old 12-28-2003, 06:06 PM   #9
Legacy777
Member#: 4800
No prob,
I'm hoping to pull off a 5spd swap in the future as well.....I've got the tranny & diff sourced......just need all the other goodies.
Old 12-28-2003, 08:07 PM   #10
Olson
Member#: 51277
1991 Galant VR4
Blk
is this kit like a street/strip type or is it just a strip kit.
Old 12-28-2003, 08:28 PM   #11
Legacy777
Member#: 4800
The kit is a shift kit......use it where you want....really don't matter. The kit fixes some of the short comings of the factory setup. A level ten setup may be a little more firm....I really don't know for sure....Just taking a guess.
On my car the biggest difference was the 1-2 shift and it firming up dramatically.
Old 12-29-2003, 08:27 PM   #12
Olson
Member#: 51277
1991 Galant VR4
Blk
sweet thanks a bunch guys
Old 12-30-2003, 03:11 AM   #13
Legacy777
Member#: 4800
no prob.
where is a good place to get an body kit for an impreza bakchoi Vancouver Impreza Club Forum -- VIC 11 09-03-2002 02:45 AM
Yee Haw, Legacy shift kit on ebay ciper Legacy Forum 5 08-27-2002 10:35 PM
Shift boot on an auto Seraph Interior & Exterior Modification 5 11-23-2001 04:24 AM
MT shift knob on an AT WRX? Geek Guy Interior & Exterior Modification 21 08-11-2001 10:34 PM
Sick fascination...the lift kit? On an Impreza? Overtime Technical Forum Archive 11 02-08-2001 09:14 PM
