Old 12-24-2003, 09:42 PM   #1
SJwrx
Member#: 14970
1997 GF8
multi
Default Chasis choice?
My whole goal is to have a chasis that is the same as the '99 2.5RS coupe. From what little I have heard, the L series uses the same chasis... is this true.
Rich
SJwrx is offline   Reply With Quote
Old 12-25-2003, 01:01 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yes from 93-01 the chassis' were the same...
-2 doors...GM
-4 doors...GC
and wagons....I forgot, oh well
Take it easy, Micah
Old 12-26-2003, 10:04 AM   #3
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
"Classic" Impreza wagon = GF
-mykr.
mykrrrr is offline   Reply With Quote
Old 12-26-2003, 11:42 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
only other consideration is that the later cars are stronger
my 93 weighs ~2500 lbs the 99-2000 RS are closer to 2850 .. but have more internal bracing
also consider a pre 96 as they don't have the obd-2 ECUs
from the sounds of it you are lookig for the some what rare 95 coupe ...
coupes were not made befor 95
Old 12-27-2003, 02:45 AM   #5
SJwrx
Member#: 14970
1997 GF8
multi
just what I wanted to hear.
Rich
Old 12-27-2003, 03:57 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
the 4 doors are lighter
scobaru is offline   Reply With Quote
Old 12-27-2003, 05:20 PM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
a legacy is better.
subiekid is offline   Reply With Quote
Old 12-28-2003, 05:24 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah by a whole 20 lbs
eat less french fries
Old 12-28-2003, 09:49 PM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
4doors are longer too better weight blance or easier to blance
Old 12-29-2003, 12:34 AM   #10
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Chassis
4doors are longer
Not so, they are the same.
MM
MZM is offline   Reply With Quote
Old 12-29-2003, 12:48 AM   #11
subiekid
Member#: 25516
is that why a body kit for a 4 door will fit a 2 door?
Old 12-29-2003, 01:33 AM   #12
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I never knew this so would 2 door side skirts fit 4 doors?
Old 12-29-2003, 07:58 PM   #13
EddyRS
Member#: 1257
2000 GC8 WRX
93 RS-W Wagon (White) RIP
YES,
In fact if you look at the side skirts (I take it you are meaning the Stock RS units and not aftermarket) The junction between the skirts (Front and back) are located right where the door seem is for the 4-door. On the 2-door it sits a bit forward to the door seem as the 2-door has longer doors then the 4-door.
As for everything else......most aftermarket kits, especially those for the Japan Market are made for the 4-door as the 2-door is very rare over there and only made for certain years. But there are a FEW exceptions, especially if the skirts are for wide body kits and or flare up at the rear wheel wells, then it is 2/4 door specific.
Just FYI
Cheers
EddyL.
EddyRS is offline   Reply With Quote
choices choices choices blakeM.U.R.T Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-17-2010 06:38 PM
BOV...choices,choices,choices.... WRX-PLOD General Community 15 11-18-2007 03:02 AM
Choices? Choices? Choices? fastbluewrx07 Rocky Mountains Impreza Club Forum -- RMIC 74 11-16-2007 03:37 PM
WWOTD...be 1st choices second choice, or be your second choices 1st pick... JBravo920 Off-Topic 22 02-04-2007 02:28 PM
Choices choices choices. rites Normally Aspirated Powertrain 3 07-22-2005 07:59 PM
